Anybody wanting to run a 10 rib blower belt needs this water pump info
During my swap from 8 to 10 rib I kept hearing conflicting information about if the oem water pump would work. I came up with a theory that pre-2009 water pumps used a wider pulley along with the different port location. To test this out I bought a 2008 Z06 water pump, and sure enough it was wide enough for the 10 rib.
'08 Z06 top, '09 LS3 bottom
Z06
LS3
Z06
LS3
so will an ls3 pump work with a 10rib?
Stock 2006 ls7 pump here.
You blower guys may want to check this out. I just got it, just because its a cheap high flow pump but the pulley on it is quite wide. Seems to be for an F-Body but it seems to take the new style thermostat and housing fine although the dimensions are a little different. I guess it's similar to the LS1/6 pumps mentioned above. Seems hard to beat for $82. Haven't run it yet though.
http://store.speedmaster79.com/p-397...dy-camaro.aspx
We have seen MANY of the pulleys come off.
(Some guys weld them on, to solve the issue)
Where's everyone getting their water pumps from. The Chevy dealership or is a auto zone brand good enough? Also was the 2008 z06 the best one to get or is the ls6 the best? This will be going on a 2013 grand sport.
Did the exact same thing - 10 rib with 8" lower, 3.8" upper pumping 32psi with no issues
Premium Supporting Vendor
Thank you for your business and for the referral!
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
