Is it fair to say the A6 just isn't adequate for supercharging?
Here is my problem, I am torn on what car to get this coming spring. One car that interest me is picking up a mint 12-13 A6 grand sport but I'm worried about the longevity of the A6. As far as I know RPM Trans does not build these anymore because no one was ever able to really solve the tuning issues. Even ECS as far as I understand it does not build these in house anymore.
I know some guys will chime in that have supercharged A6 cars and are lucky enough to not have blown up the trans yet. I know with modded cars you always run the risk of blowing something. I'm ok with that. What I'm not ok with is knowing if I blow it up there is no solution except to put another A6 in the car and hope it lasts longer. Am I wrong on this or is there no real solution for this? I'd plan on doing the following mods.
ECS novi
Arh headers
Meth injection
Small blower cam.
Probably around 600rwhp and call it a day.
I'm not looking to forge and turn the boost up but at least I know if the motor Did blow that's certainly an option I have. I hate not having a fix for the A6 problem. I know a manual would solve this problem but a forklift accident many years ago makes that rather difficult and takes the enjoyment out of the drive for me. Any info into this problem would be appreciated.
ECS novi
Arh headers
Meth injection
Small blower cam.
They are fine at 600rwhp, just don't go up much higher, and get a really good tuner.
Even if my motor went and I forged it would just be for peace of mind and I'd only turn the boost up slightly. I know I'm in the minority here but 600rwhp seems to be the most I'd want in my weekend warrior
I am going to try 750 in my A6. My CTS-V made 800whp through an auto. I think the trans is similar and the Vette is much lighter.
People that break them I wonder if they are flooring them in drive. That is really bad to do that.
What do you mean? What should they be doing?
It's all in the tune. I had a 650 whp, with no issues with my 6l80. I did change it for a 4l65, but that's because I could and everyone talk like the 6l80 was a ticking time bomb. Who knows!
Former Vendor
You should have it upgraded if you are planning to track it regularly. Stock clutches won't last at that power level. And the tune can make or break you literally.
I don't plan to track it regularly but occasionally I can see that. It's mostly a street car and typically I'm not very hard on my cars. What upgrades do you suggest.
How do you like the 4l65 and how much did the swap cost you. I'm very glad I made this thread. Now at least I know there are options out there.
Ok I'll speak to ECS first and then talk to rpm and century to see my options. I'd think though doing the mods I listed including the ECS small blower cam it may put me a little over 600 Rwhp. Maybe i should leave the blower cam out? Still I guess I can just roll with the A6 till it goes and then pick an option.
Does anyone know what this poster may have meant? If you don't want to use the paddles but were going from a highway roll what would you do? It's been a while since I owned a c6 I'm trying to remember how the shifter looked.
I think what the poster meant was about kickdown. Full throttle kickdowns with a blower are just violent with these cars and very hard on the trans. A good tuner can make them much better, but its better to use the paddles if you are roll racing.
If your only lookin to make 600 you don't need a cam to achieve that w/ a Grandsport... Blower, Headers, & Meth is all you need
Is the only benefit to the cam more power and a cooler sound? If so I guess your right maybe I'll just do the mods you suggested. Btw I pm you awhile ago. Not sure if you ever got it.
At 600 rwhp the trans should live fine with a good tune and a cooler. Its also very dependent on use. If you are not hard on it you shouldn't have problems. If you track it a lot and drive it hard all the time I will bet it wont last too long.
I would never floor it while in a high gear. If I want to floor it while rolling I paddle down to the appropriate gear. Then floor it and shift to drive and let it do it's thing.
