Need some Fuel rails and fuel line advice.
Wrapping up my F1R build. What -10, -8, and -6 fuel line do you guys recommend. I am eyeing some SS, black nylon wrapped, stuff to go for a cleaner look.
I sold my FAST rails with my 102 intake so what black rails do y'all recommend to use with a stock LS7 intake?
Thanks for any recommendations.
Thanks for the replies.
I have put together my own system as I already have a Walbro 450 in tank. I have a Magnafuel Pro 750, Fragola 545 reg, Fragola in line filter, and ID 2000s. I will look into the aero motive rails.
I went holley ls kit..powder coated black made my own lines
Nasty Nate rails are nice if you can get them in a timely manner other than that the Holley rails are nice and are about $100 cheaper.
Holley rails are cheap and great quality. I use Aeroquip startlite hose with red horse fittings. -8 feed, -6/stock feed line return
More info in my build thread
https://www.corvetteforum.com/forums...ld-v2-0-a.html
I'm running RSI rails, but had a set of DP rails I wish I kept. All setup for stock ls7 intake.
There are plenty of rails that work, not just the aeromotive.
RSI, Nasty Nate, Dallas Performance, Fast, Katech, Norris....
Those rails say they work with the FAST 102 and say nothing about the stock manifold. Are you saying that if they work with the FAST they will be ok with the stocker?
Call the vendor and ask. I know I've had RSI and DP on my stock ls7 manifold, and fast 102. Just different mounting tabs that bolt on. Easy for them to have two slightly different mounting parts.
