McLeod RXT/RST Twin vs Mantic 9000 twin vs Monster Level 1 twin
So I took my car (2012 Grand Sport) in for shifting issues and the dealer decided it was bad synchronizers, so they're rebuilding the trans with new synchros under warranty. I asked if they'd install a new clutch at this time and they agreed (provided I buy the clutch of course).
I plan on making about 600-650whp in the long term with this car at ABSOLUTE MAX - (LTs, novi 1500, stock heads/cam).
The main thing on my mind is "stock like" engagement. This car is my DD and my ONLY CAR. So the driving like a stock clutch thing is NON-NEGOTIABLE. I'd like no more pedal effort/stiffness than stock.
Ideally I know most folks would recommend a twin, so here we are.
The next biggest thing is price... I've never spent more than $650 for a clutch and I realize twin discs are general more expensive (simply put, more parts)... but $1700 for a clutch?! Jeez man... awfully spendy for a car that'll never see 700whp, let alone the 900+ some of these clutches are boasting.
I really like the price of the McLeod RST twin as Hinson has them for very reasonable prices, and it looks like the RST would support the power.
So with the above stuff in mind. I'd like feedback, specifically from folks who have driven more than one of these clutches - Or at minimum, a critique of the difference over stock.
Thanks!
Thanks!
CorvetteBrent (10-04-2018)
I've driven RXT, LS9, Mantic. They all drive great, good pressure/pedal feel/etc. I would suggest mantic because they just work and drive great. RXTs are good too, but the QC at McLeod is subpar and I've seen a lot of them need adjustment or sent back. As long as the dealer is willing to measure and and shim/etc to make it work, or send it back and wait for a new one then it isn't a bad option, but I doubt they are going to do that for free or let your car sit there for a week or more waiting on new clutches to come in.
If you don't plan on launching or running a sticky tire, stock clutch will work for you and you may want to save the money.
I run a McLeod RXT I love it. These are some things I learned along the way. If you get a McLeod clutch call mcleod and tell them you heard they had a small batch of out of spec clutches and you want to buy a new one from them. They are on top of it, even if you bought an older one, if you call them with the serial number they will tell you if its one of the suspect ones and replace it free.
I recommend buying one of their billet flywheels when doing the install. If you are going to use a tick master cylinder DO NOT use a McLeod throw out bearing, use a stock GM.
Good luck with your choice, you don't have to spend 2k to get a great clutch and flywheel to hold big power.
Unreal said what I would have. Mantic 9000 is the way to go unless you stay stock.
I would go with a Mantic 9000.
I have a RXT in my car, but I cannot for the life of me recommend it. I had nothing but engagement issues with it that resulted in McLeod recommending to buy their $400 adjustable slave for something that should be "plug and play". Between that and the additional expense of having to rip my drive train out multiple times I will never tell someone to go with a McLeod.
If he isn't drag racing it I would go with organic disks on whatever it is. I don't care what anyone tells you a ceramic disk will not drive as nice as organic.
Staticki, that is why I don't recommend them. I've seen it happen time and time again. People melting slaves, engagement all over, won't disengage, won't shift. Local shop installed 3 of them, all wouldn't disengage, finally when RPS and no issues. When they work, they are great clutches, and if you are installing yourself and don't mind dealing with the hassle, maybe get one, but I rather just run a mantic and not worry about it.
Former Vendor
Thanks!
Thanks!
At that point, I should've spent the extra coin and went with the mantic who stand behind their product.
Mcleod should tell their customers that their throw out bearing wont work with the ticks, you need to go GM for that. It would save a lot of pain and money.
I have nothing against Mantic, for all I know they might be better than Mcleod, just saying my RXT is a monster, but its set up right.
The rxt is great when it works. But after my issues with their product having incorrect tolerances and costing me lots of time, labor and slave cylinders I could never recommend it to someone else over the whatever the new popular clutch is, which these days seems to be the mantic
Mcleod did a **** poor job letting distributors know about the bad run of clutches they had.
Also, I know people who bent the fingers on their clutch's because they used McLeod's throw out bearing with a Ticks master cylinder. WHY McLeod wouldn't warn customers about that is beyond me.
I did a clutch, rear, trans, and half shafts at the same time. I was paranoid because it was my first time working on a C6 and the amount of labor involved in the job. If I didn't personally pick up the phone and call Mcleod (which I shouldn't of had to) I would have been in the same position you were in.
Another Vote for Mantic here.
Thanks for the tip.
I just ordered a Mcleod RST & billet flywheel, was it just the RXT model that was affected?
Im gonna call them once I recv it to make sure its not a bad unit
Measure the distance from throw out bearing face to pressure plate fingers and make sure it's within spec
I have a brand new rxt kit sitting around to replace the stock one whenever decides to go south. This thread is making me nervous. I guess I can call mcleod and provide the serial number as it was suggested. It's a shame that such an old and recognized company failed to recall those known bad clutch kits.
I think Im just going to cancel my order with Hinson & get a mantic 9000, hopefully they didnt ship it yet. Sucks Ill lose money on the balancing option, but Id rather not have any issues.
Mantic is a great clutch, however mine has started to develop some chatter only at launch when it gets warm. I'm at around 500 miles on the clutch, so not sure what that's all about. It doesn't do it when it cold. Other than that the engagement and peddle feel is awesome.
Local shop got a "good mcleoud" 3 times, that wouldn't disengage. Kept sending it back and getting bad ones from them.
I convinced them to send me a flywheel from their 'street twin' clutch for free and it worked because the flywheel was so much thinner it reduced the stack height to reasonable measurement when compared to throw out bearing face position.
I would avoid doing business with McLeod at all costs... I'd rather try to run a stock clutch
