C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
TiAL BOV w/ Procharger D1SC kit
Old 10-02-2014, 05:36 AM
g8gt208scvette
g8gt208scvette's Avatar
Default TiAL BOV w/ Procharger D1SC kit
Hi guys, I am wanting input on switching the pro-flow bypass valve included with the Procharger D1SC kit for the TiAL Q BOV. This was recommended to me by my mechanic and he said the one that come with the kit sucks and stays open to much and looses boost. How is this BOV with this head unit? I don't want to overheat it or cause any problems, I don't care about the cool sound. Is it worth swapping or should I get the big red bypass valve?
Old 10-02-2014, 08:30 AM
Detoxx03
Detoxx03's Avatar
I run one on my car with a -6 spring. One of my favorite mods.
Old 10-02-2014, 08:33 AM
g8gt208scvette
Cool thanks for the input...what made you go with that spring? Can you estimate the amount of boost your car will make and size accordingly or would it be best to have your car all put together and measure the boost then buy accordingly? Because right now my motor is getting built and my car isn't put together so I really have no idea have much boost I will actually have.
Old 10-02-2014, 08:41 AM
Mike Farris
Mike Farris's Avatar
I have one as well. I cut the bung out for the proflo and added the tial flange in its place. Definitely seals better.
I have the -3 spring as recommended by ECS and Tial. Seems other spring pressures work as well. I may try a stiffer spring to keep it closed more often.
The spring is based on engine vacuum not boost level.
Old 10-02-2014, 08:43 AM
g8gt208scvette
I'm sorry that's what I meant Mike...How would would determine engine vacuum without having the engine and everything together? I was wanting to go ahead and purchase now.
Old 10-02-2014, 08:46 AM
g8gt208scvette
Also, where I purchase the BOV from?
Old 10-02-2014, 08:55 AM
Mike Farris
I think I got mine from Amazon. Vacuum will be based on your cam selection but I think most every cam I've seen on here will produce enough for any of the springs Tial makes. Lighter springs will have it venting more often which should keep the intercooler cooler. Stiffer springs hold it closed more and are less annoying. Thats my take anyway.
What are your cam specs and size of the new motor? Maybe someone here has something similar.
Whatever springs you run will be an improvement over the procharger part.
Old 10-02-2014, 09:34 AM
g8gt208scvette
I don't speak cam lingo very well so hopefully I am writing this out, my cam is 227/240/50 .636 lift 115 lsa +4
Old 10-02-2014, 10:16 AM
Detoxx03
Detoxx03's Avatar
The spring was recommended by ECS based on my cam and vacuum.
Old 10-02-2014, 10:28 AM
grocerygetter
grocerygetter's Avatar
I love mine and know for a fact it works and flows better than my Vortech maxflow did on my ls3 camaro kit.
Old 10-02-2014, 10:50 AM
g8gt208scvette
my tuner recommended a 10-12 psi spring...what you guys think??
Old 10-02-2014, 12:45 PM
0CravenPerformance
Former Vendor
CravenPerformance's Avatar
The bigger your cam (More Overlap) the less vacuum you will have for the most part. With that cam i would be looking at a 8psi spring to start and fine tuning from there.
Old 10-02-2014, 12:50 PM
g8gt208scvette
Do you sale the BOV?
Old 10-02-2014, 12:58 PM
0CravenPerformance
Former Vendor
Yes we sure do. Give me a call and i can get you one.
-Reid
Craven Performance
636-397-1500
To TiAL BOV w/ Procharger D1SC kit
Quick Reply: TiAL BOV w/ Procharger D1SC kit
