NEW** LS and LT1 intake manifold
pretty cool
Saw this at SEMA. It's a shame that it is so ugly, but that is just an opinion. Would like to see results and how it will handle boost.
if it will fit under a c6 hood and hold boost, I'd be down to try it with an ECS kit in front of it. Typically, a FI car (centri or turbo) doesn't see gains from an intake or TB change...or shall I say not see major gains. But, I've seen some that did. I'd be open minded.
Looks like a good intake! Like that the plenum volume has increased as I think that often gets overlooked in after market intakes.
No reason this won't make more power than stock on a boosted application! Remember with boost you are just increasing the density if the air the engine is sucking in! You don't blow air into a engine even with boost!
Received 2,276 Likes
C4 of Year Winner (performance mods) 2019
It's like saying you don't need better heads on a boosted engine!
I just bought one. It's supposed to be here on the 18th. I'll measure it against my stock ls7, and my FAST LSXr.
if I can find a flow bench, I'll have it tested against the FAST.
Do you have a NW 102? What are your numbers now with it basically being a stock motor? Just so we know where you're starting from...
I'm building an RHS465 in my C6Z. I don't have any baseline numbers, but I plan on testing it with both my FAST and the new one to make sure I'm not hurting myself to run it.
Found it on Summit's site. Aztech needs you to register as a dealer.
http://www.summitracing.com/search?S...ake%20manifold
