C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Well, I finally did it.. (ECS /FSP)
Old 03-04-2015, 02:03 PM
  #301
schpenxel
schpenxel's Avatar
Received 1,193 Likes on 1,052 Posts
St. Jude Donor '15
Originally Posted by djfury05
Cool thank you. Let me know how they work out. I just ordered the kit last night so it's not even shipped yet.
Will do.. I think on the 6 pin connector you can take most of the wires out of it because they aren't used.. although I guess you could also just leave them in the connector (just not connected to anything) to avoid having to worry about them touching anything on accident
I'm probably just going to order a big pack of weather and metri pack connectors so I have plenty on hand. I always order them one or two at a time and always wish I had more.
Old 03-04-2015, 02:06 PM
  #302
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,079 Likes on 653 Posts
Originally Posted by Unreal
Yah, searched and finding mixed info. Looks like he has a check valve right on the nozzle. My dual kit doesn't have those. I'll go check mine out.
Dual nozzle kits have the check valve at the filter and the std single kits have them at the nozzle.
Also I personally mount everything except the LED hidden away and out of easy reach simply so it does not get accidentally moved/changed. Meth is fuel, so you are changing your tune when you change the dial. Once it's tuned correctly it should not be changed, same as the tune in the ECM since it is now part of the equation.
Hope that helps.
Old 03-04-2015, 02:08 PM
  #303
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Hope that helps.
Any suggestions on location? Glovebox is pretty well out with all the other electronics I have in there already.
Old 03-04-2015, 02:12 PM
  #304
Nosferatu
Nosferatu's Avatar
St. Jude Donor '14
Originally Posted by schpenxel
That's awesome. I already need new shocks, one rear one in particular is beyond gone, so I already get weird things happening under hard acceleration or braking. I guess > 600RWHP won't help that
Bilstein B8 (the stiffer optioned ones forgot name) are what I run. They are great to me on the C6 over factory.
Old 03-04-2015, 02:14 PM
  #305
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Good deal.. DRM (I think that's the name anyways?) is local to me, so I could pick up a set from them pretty easy. Actually I was suppose to already but had some torque tube troubles I had to fix first and never did go get them. Viking also has some that aren't too stupid expensive, but are adjustable too.. so those sound nice, but perhaps more than I care to mess with.
I've heard the regular Bilstein's like you mentioned are probably the cheapest good option out there.. better than factory and not too expensive
Old 03-04-2015, 02:40 PM
  #306
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
I ran the DRMs, and now Vikings. Spend the extra $100 and get the vikings. The adjust ability is great.
Old 03-04-2015, 02:44 PM
  #307
schpenxel
schpenxel's Avatar
St. Jude Donor '15
They seem like a good option.. wouldn't surprise me if I end up with them
Have to get a torque tube input shaft issue taken care of first though. I'm so looking forward to pulling that back apart. At least it won't be freezing this cold this weekend
/sarcasm
Old 03-04-2015, 02:47 PM
  #308
Unreal
Unreal's Avatar
I would do RideTechs from ECS if I was baller, but for ~$670 or so, the Vikings are working great. Smooth for daily, stiff and handle well when needed, and nice squatty when set to drag settings.
Old 03-04-2015, 02:49 PM
  #309
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Hard to beat for < $700. I'd love to spend like half that and get the same thing, but that doesn't exist, so it is what it is.
Until I win the lottery that is.
Old 03-04-2015, 02:52 PM
  #310
DOUG @ ECS
DOUG @ ECS's Avatar
We mount the gain **** box above the hood latch, there's an open area there, and the PAC module behind the knee bolster.
Old 03-04-2015, 06:13 PM
  #311
djfury05
djfury05's Avatar
What are you using as a harness to breakout the IAT and relocate? Only one I seen on eBay worked for an LS1 with old 3 wire MAF and IAT females separate then combined into 5 wire female connector.
Old 03-04-2015, 06:15 PM
  #312
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Racetonix makes a breakout harness.
Old 03-04-2015, 06:18 PM
  #313
realcanuk
realcanuk's Avatar
St. Jude Donor '13
I almost couldn't sleep last night trying to remember about the meth check valve thing. Today I went to the shop and looked and as Unreal said, I have the filter and check valve combined. I remembered removing the single nozzle valve, but not adding this one..
Old 03-04-2015, 06:46 PM
  #314
djfury05
djfury05's Avatar
I looked on their site and didn't see one that would work. The one they advertise are for use on 98-02' F-Bodies with the 3 wire maf and IAT separate.
Old 03-04-2015, 07:03 PM
  #315
schpenxel
schpenxel's Avatar
St. Jude Donor '15
All you need to do is buy an IAT + connector and connect it to the wires that used to be the IAT sensor on the MAF assembly.. no break out harness needed. Although I think they're on eBay if you wanted to go that way
Something like this:
Amazon.com: GM Open Element IAT Sensor with Uncrimped Connector by DIYAutoTune: Automotive Amazon.com: GM Open Element IAT Sensor with Uncrimped Connector by DIYAutoTune: Automotive
(obviously I'd check this wiring diagram prior to using it.. not 100% sure it's the right one)
Old 03-04-2015, 07:46 PM
  #316
djfury05
djfury05's Avatar
Yea I thought about that too. Probably be cheaper that way since I have to get the actual sensor still. I found this pinout of the LS7 MAF, should be pins D & E that need to be re-routed to the IAT breakout.
https://www.corvetteforum.com/forums...post1566267638
Old 03-04-2015, 09:05 PM
  #317
realcanuk
realcanuk's Avatar
St. Jude Donor '13
I bought so much stuff lately I got mixed up. I used this from Caspers......
http://www.casperselectronics.com/st...oducts_id=1108
To Well, I finally did it.. (ECS /FSP)
Old 03-04-2015, 09:14 PM
  #318
djfury05
djfury05's Avatar
Yes another member PM'ed me that. It's going to be cheaper for me to just de-pin and extend the wires since I had to buy the sensor too. Got it all on order now.
Old 03-06-2015, 08:53 AM
  #319
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Here's a list of all the METRI-PACK connector part numbers for 2 through 10 pin connectors
Pins
Male pins 12045773
Female pins 12048074
Housings/TPA's:
2 pin male 12162000
2 pin female 12052641
2 pin TPA 12052634
3 pin male 12129615
3 pin female 12110293
3 pin TPA 12052845
4 pin male 12162102
4 pin female 12162144
4 pin TPA 12047948
6 pin male 12124107
6 pin female 12052848
6 pin TPA 12052850
8 pin male 12047931
8 pin female 12047937
8 pin TPA 15324525
10 pin male 12045808
10 pin female 12065425
10 pin TPA 12124264
Seals 15324973
Cavity plugs 12059168
Old 03-08-2015, 02:14 PM
  #320
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Uh oh.
Quick Reply: Well, I finally did it.. (ECS /FSP)
