Well, I finally did it.. (ECS /FSP)
#501
Received 1,193 Likes
St. Jude Donor '15
I noticed the vacuum caps on your intake are cracked, I put brand new ones on mine and within a matter of months they looked worse than yours... I ended up finding some silicone vacuum caps that can withstand 600+ degrees, they aren't cheap but will hold up for a lot longer than the rubber caps
I picked up a "breakout harness" from campers electronics that was a plug and play to add a IAT sensor. It's pretty slick looking. http://www.casperselectronics.com/st...oducts_id=1137
In my case I decided to just re-pin/extend the IAT wires so it will reduce the clutter. If I ever have to go back to 'stock' to sell it or something I'll just leave the IAT sensor where it's at anyways
#502
Received 1,260 Likes
I had to get a few different sizes because I have pretty much all my vacuum ports capped... here is the place I got the silicone caps from http://store.034motorsport.com/catal...ilicone+nipple
#503
St. Jude Donor '15
#504
#505
St. Jude Donor '15
And I'd rather not have the current ones disintegrate on me.. they look like they're a vacuum leak waiting to happen
#506
St. Jude Donor '15
So, what are other guys seeing intake air temp wise from the ECS kit? (in terms of degrees above ambient)
I'm seeing right around ambient now when I'm on the interstate.. I used to see maybe 5-8* higher, but I'm wondering if the sensor was reading a little higher than reality. Either that or this one is reading a little low. I tend to trust a brand new sensor + ZR1 calibration data though, but who knows.
#507
St. Jude Donor '15
It looks like you are doing a great job, but I am not sure I see the advantage to vs. putting it in the pipe after the meth nozzles. Although meth spraying on the sensor will obviously not give an accurate reading, it allows using the IAT's as a safety precaution in case of meth failure, which cant be a bad thing.
It will be interesting to see much the temps drop in hotter weather. Obviously it's pretty cool here today compared to how it has been
#508
Good news.. it does seem to be working as intended. I went from ~45*F IAT's to 20*F in about 2 seconds (ok, maybe 3).. so I think that's working pretty good
Always enjoy your thorough updates.... keep up the good work.
#509
St. Jude Donor '15
Good that it is still useful for safety. My point was more that it is very cool, I just don't see any advantage. I guess if the intake is off already, then its another good option. I personally wouldn't pull my intake to do it, if its doing the same job.
Yeah, I just preferred the way it looked honestly.. If I had a TIG welder I probably would have installed a 3/8" NPT bung on the intake tube right after the meth nozzle and called it done (I bought the bung actually but then decided to try the intake idea instead).. I thought putting it in the intake was a pretty neat idea and it looks pretty good once it's done. I had considered using the rubber grommet way and just drilling a hole in the intake tube but I don't really like the way that setup looks. I'm sure it works fine though. The intake came off pretty easy and it gave me a chance to do a little cleaning anyways (which I'm sure some of you guys are happy about! haha)
So, what's the lowest IAT reading anyone has seen (you don't count canuck since it's like -20 up there anyways!). I got down to 20*F earlier. It's about 50*F here right now.. I'm really surprised it gets THAT cold.. I thought with it being this cool already that I wouldn't really notice it as much. Guess I was wrong though
Anyone running meth want to share their IAT tables? (base + multipliers)
edit: scratch that.. I got to 14*F apparently. That was just messing around though.. not at WOT
#510
Thanks!
A full throttle dyno pull was 135 without the meth, and if I remember right about 65 with it.
#511
Post up your results I did a dyno pull last night with ambient temps of 45-50ish meth dropped IAT to 40 and the car really loaded up on fuel wouldn't pull over 4700-4800rpm it was fine on the street so idk.
#512
St. Jude Donor '15
#513
Not sure what results you are asking about. Maybe you are dumping too much meth, or the tune is just too rich up top.
#514
St. Jude Donor '15
I used the "regular" IAT sensor table from a ZR1 calibration
You're supposed to use the data from the IAT "2" table, which is the sensor in the manifold
I changed that and will give the new cal a try soon
I was wondering how I was getting down to or slightly under ambient without meth
(my ambient sensor reads a little high so I figured it was just that)
#515
St. Jude Donor '15
Quick update since it's been a little bit since I've updated:
IAT's make a lot more sense now that I corrected the IAT calibration info... I was wondering how I was getting down to ambient and even slightly under (without meth) lol.
The tune is getting there, slowly but surely.. I'm down to about 1-2% AFR error in PE now up to about 4000 RPM's, so I think that's pretty good. Haven't had much time to spend on it lately and have been driving another car to/from work. I don't know how much higher I can tune on the street.
I'm thinking about installing a Z06/ZR1 exhaust system.. I found a setup from someone fairly local to me for a great price. They flow quite a bit better than the factory LS2 system, are cheap, and have cats that survive on the ZR1, so I give them a better shot at surviving than factory LS2 ones (or most aftermarket ones for that matter). 20+rwhp gain on NA applications, supposedly. Now I wish I hadn't bought these replacement LS2 cats. Total waste of money, but maybe I can manage to sell them
Still thinking about it though.
Next I'm swapping over to a PLX wideband.. this Innovate Motorsports MTX-L is giving me too many problems and I really don't trust it anymore.
Then I need to open the restrictor plate up a little bit
Then at some point I need to get some time on a dyno for a few runs
#517
St. Jude Donor '15
Update for today--Decided to check for boost leaks. I took the tube that connects the air filter to the supercharger off, put a thick ziplock bag over the inlet, put the tube back on and clamped it down. Then I pulled the hose off of the hobbs switch connected to the BAP and connected compressed air @ 15 psi. I could hear something hissing.. so I sprayed soapy water on all the connections. I didn't find anything major (I don't think anyways). All the major connections looked good, no bubbles.
I did find leaks around the MAF, meth nozzle and the vacuum splitter thing that the bypass valve and BAP hobbs switch connect to. I'm not sure any of these are big enough to matter, but I'm going to try to fix them.
The meth nozzle I think I can just tighten the nozzle down a little more. It's leaking the least of the three.
Some sealant on the small connections on the vacuum splitter should seal it right up.
The MAF sensor I'm not sure about though.. and it's the worst leak by far. It's tightened down and the seal looks good, so I don't know what else to do with it. Any ideas?
#518
I know this may sound dumb but is the maf installed upside down? I had same prob when i made that mistake or replace rubber in maf or buy new maf. Could be intake portion is not sealing too. Only you can tell, im sure youll fix it bud.
#519
St. Jude Donor '15
I'm not real impressed with the smoothness of the sealing surface on the charge tube since it's been powder coated, but no idea if that's why it's leaking or not. I could just block the whole MAF opening off and go SD and be done with it since my IAT sensor has already been relocated.
Either way, I'm not even sure if these leaks would even matter.. I just had some free time and thought I'd see if there was anything major leaking and only found these small ones. Probably worth fixing though
#520
The maf looks to be the right way. Anytime you powder coat anything its best to tape off any areas that will get something attached to it. Especially if its something that has to seal well. I would just check that the seal there is good, and maybe clean the surface it mates to.
