Well, I finally did it.. (ECS /FSP)
#861
Received 1,193 Likes
St. Jude Donor '15
Yup.. never ends, lol. I really think it's best to at least do valve springs/trunnion though given the mileage on my stock ones. Cam is still debatable..
Thought about doing the cam while the radiator is out but don't really want to spend anymore money right now. Maybe in a few weeks.
#862
St. Jude Donor '15
29K VIEWS!
Got radiator swapped this morning. Pretty sure I had a bail of hay in this radiator. Check out the pics.
New pressure sensor w/Schrader valve dimple built in. It would be perfect for connecting to the fuel pressure port on the fuel rail, but I have some other ideas to try first
Dimple... I think you can leave the valve in the fuel rail connector if you use this type of pressure sensor
Just a little bit of grass in this thing. Jesus. The radiator install went OK, no major issues.
Then I got home and found my package from BTR had arrived. Valve springs & Trunnion upgrade
Trunnion stuff
Valve springs.
Seals
Dual springs
Springs
Mo' springs
Trunnion stuff
Valve springs.
Seals
Dual springs
Springs
Mo' springs
#863
St. Jude Donor '15
On the to do list for today:
Replace Valve springs
Trunnion upgrade
Install npp hoses
Replace Coolant reservoir
Replace End links
Pics coming later.
Happy 4th everyone!!
Trunnion upgrade
Install npp hoses
Replace End links
Pics coming later.
#865
St. Jude Donor '15
Got everything but the npp hoses done. Valve springs were a bastard but finally got them all. I do not recommend the ls1tech tool for valve springs. Pics later. Then beer. Possibly not in that order.
#867
Can you PM me where you got the Honeywell pressure switch? I've been looking for a simple solution for attaching a fuel pressure sensor to the Schrader valve, and that looks perfect.
#868
St. Jude Donor '15
#869
Curious why you don't recommend the ls1tech tool. Been using one for years.
#870
St. Jude Donor '15
Sensor:
PX2AF1XX150PSAAX
http://www.mouser.com/ProductDetail/...JtzHWFBA%3D%3D
Connector:
12110192
http://www.mouser.com/ProductDetail/...2f4Jveqx5UM%3d
Pins:
12110236
http://www.mouser.com/ProductDetail/...bngJUy5zZmw%3d
I haven't assembled mine yet but I'm pretty sure those are the right pins.
#871
St. Jude Donor '15
The other tools might not be any better though, I've never used them... but I have a feeling they work a bit better. They cost 2-3x as much though
It DID do the job.. so I can't complain too terribly much
#872
St. Jude Donor '15
#873
St. Jude Donor '15
#874
There you go again with those OJ gloves!
Dude, all I can say is, you are truly a wrench addict! I bet you sleep with a set of combination wrenches under yer pillow!
Reminds me of a fellow I once was, back in my younger days...
I take it you're using the TDC method to change the springs, since I don't see any air hose going to the spark plug hole?
I can only imagine that single spring tool could be a PITA with twisting around when you're tightening it down.
BTW: were you using that Vette as a mower?? I haven't seen that much grass in one spot since my days as a drug prosecutor!!
Glad to see you're enjoying your project though. You'd get my vote for the Wrencher of the Year award fir sure!
Keep on wrenchin!
Keep on wrenchin!
#875
St. Jude Donor '15
Keep on wrenchin!
Keep on wrenchin!
Yep, used the TDC method. I basically just stuck a 1/4" extension down the spark plug hole and spun the crank a few degrees, checked, turned again, repeat until I got close enough to TDC. I didn't trust the air compressor method enough to try it
Yeah.. you're exactly right, the spring tool would try to rotate and as it went down it didn't stay quite on the same plane as the valves, so you'd constantly have to move the springs around to keep everything lined up. Not a huge deal but def. had a learning curve
That radiator was nasty.... as you can imagine, my coolant temps dropped a little bit with the new one. Didn't know you were a prosecutor though! I bet you have some crazy stories from those days.
I think this will be about it for a while though.. I need to connect the NPP exhaust and at some point change brakes/shocks, but that's about it. Until I do a cam that is
#876
I've never had issues with the spring tool rotating but I've also never used the tdc method either. Maybe the valve trying to move has something to do with it. With 100 psi mine stay put. Glad to see you got it done though.
#877
well I think it was brought up in this thread at some point (if not it was elsewhere) about whether or not the DashLogic would show a low windshield wiper fluid warning for those running meth. The short answer is yes.
Someone else's car had the "check washer fluid" warning on their dash. I opted to plug my DashLogic in and voila it shows what I wanted it to show.
Just figured I'd answer that question for you schpenxel as I remember it was brought up a while ago.
#878
#879
St. Jude Donor '15
Speaking of which, I need to go get some more methanol!
#880
right because every message that comes through that DIC gets masked by the DashLogic. As long as you have a custom warning programmed into it it'll show (as I just demonstrated). I feel better now beating on the car.
