Well, I finally did it.. (ECS /FSP)
#1321
I got a spare pump in the garage. Julio suggest maybe once a year just swapping them out and sending old one back for a rebuild. I think it is like $60 to rebuild one. Cheap for what you get.
#1322
Received 1,261 Likes
do you think it could have anything to do with the adjustments on the pac unit itself?... I remember my tuner had to fiddle with those a bit when we cranked the **** all the way up but I don't remember what they were for
#1323
I've played with the PAC settings a bit. One **** controls when the meth starts to spray based on input from your MAP or MAF converter. The other **** controls the amount of meth sprayed on that initial activation. At least that's how I remember them working off the top of my head. If you mess with one, you usually want to mess with the other since they affect each other.
Maybe your issue could be wiring or relay related? Seems kind of early to have a pump crap out, but I guess anything's possible. Maybe moisture from all that rain is wreaking havoc on some electrical connections or components? Just a thought...
#1324
Received 1,194 Likes
St. Jude Donor '15
That's what I was planning on doing too--first year I was just going to buy a new pump so I'd have a spare, then send the old one back for a rebuild before I hit 2 years (assuming I keep the car that long, etc.)
#1325
St. Jude Donor '15
Figured it out... the eff'ing hose was loose where it connects to the nozzle at the charge tube. I'm just glad nothing caught on fire. When I hit the test button meth sprayed all over the place. I must have loosened it while I was messing with either the evap system or when I was putting the black covering stuff on the meth hose.
So.. pulled it apart while I was at it and cleaned the filter, etc.
Put it back together and now the green light comes on very quickly when hitting test. Took it for a spin and it quickly maxed out my wideband on the rich side.. so, it's working now. Need to pull a little fuel out.
This should also solve my problem of there being a delay the first time I used meth after the car was off a while.. I had to hold down the test button a few seconds before it would start actually making any difference.
So, yeah, I feel like an idiot. At least I'm not an idiot with a burned down car.
#1327
we will have to ad this to our PM list.
#1328
St. Jude Donor '15
I did clean the filter on the nozzle while I was messing with it... It had some white gunk on it. Some Dawn and a brush took whatever it was right off, though I'm not really sure what it was
I don't think it was blocking much but figured I might as well at that point since I had it apart. I haven't been able to drive it since unfortunately. It's been raining like crazy here. Hopefully tomorrow it will be sunny for the first time in two weeks
#1329
St. Jude Donor '15
Finally was able to drive it again today. Between raining the last two weeks and travel for work I haven't driven it in a while besides a 2 mile trip after I found the meth hose loose.
Was about 7% richer now with the meth line connected properly, so that is good, I guess. Pulled the boost VE table down about 5% to take some fuel out. I'll mess with it more tomorrow but I get a green light on the meth system quick now, so that is good
Saw almost 10psi at 5,100 today. I may put the restrictor back in if boost keeps climbing fast. I don't spin it over 6K so it may be fine, just depends.
On the other hand, I'm running the stock cam & Z06 headers, so not the best flowing which equals more resistance = more "boost".
Or I could turn the meth **** to 10 and have at it and hope for the best
#1330
There's nothing wrong with the stock cam. You really should "do it right" and put it on a dyno to tweak it the way you want it.
#1331
St. Jude Donor '15
Very true.
I need to look around and try to find a local shop that will let me spend a little time on their dyno
#1332
St. Jude Donor '15
I know, I know.... I want to. We'll see
There's one shop down in Charlotte that has a dyno I could probably use. I buy my methanol from them and have talked to the owner a good bit and he seems pretty laid back. He has a twin turbo viper in the lobby too
#1334
Drive her up to Buffalo, I'll buy wings and beer lol
#1335
St. Jude Donor '15
lol, if I'm ever up that way I'll let you know!
#1337
Yea I'm not sure what that fuzzy white stuff is but it's worthwhile for those who haven't to do some PM on the filters. This is after 2-3 years. Top one cleaned, bottom not.
#1338
that is odd but I suppose the filter is doing it's job... are you using straight meth or a mixture?... not sure if that would have anything to do with the buildup or possibly there was something in your washer tank or pump that contributed to it?... I had my nozzles on for about a year and when I swapped them out the filters looked new
#1339
Straight meth. I don't think its something in the tank. Just years of use. I'm probably wrong on the lifetime of these nozzles. It's been a while.
#1340
St. Jude Donor '15
Yeah mine was looking similar to that though not as bad.. I've only used VP M1 meth so it should be clean stuff I'd think?
I dunno.. All better now though!
Rear tires broke loose near top of 3rd this morning again when getting on the interstate, lol. I always get some funny looks when I go from normal car getting ready to accelerate on the on ramp to blowing the tires off at 70+ in no time
