New winter project.. going to need help from the experts !!
I could tell you if it was an ECS kit, but even then there is some guess work involved. I had to try 2-3 belts to find the right size. Current one (52.25" I believe) barely fits on, and took 2 of us an hour to wrestle on. The 52.75 goes right now by myself, and puts tensioner in the middle.
Abdul (local 1300rwhp Dsteck/CBI built car) runs a A&A 8 rib ysi/direct drive, and would be a good person to ask.
I have to check my lower. ATI 8% overdrive. I will get the size. For the upper I don't imagine I will be going that small, but you never know.
Just do it and use a restrictor plate to limit peak boost. That way you don't loose the bennifit of the blower spinning fast out of the gate.
You would have to make it, you are basically just slightly restricting the inlet side of the blower. ECS does this with their basic kits, it works very well.
whoops, nevermind, that's for a 10-rib 6% OD.. not sure what yours would be.
This is what I have.. quote from ATI email...
8 rib damper P/N 917345 by itself you have to specify that you want it built with the 8% overdriven shell assembly P/N 917107
Guess I will call also.
I would just keep the eforce if it was me. Best blower ever, and PD torque can't be beat.
I just looked up the one they sold me. It says 7.53 on there site. Are we talking damper or shell assembly size ?
I use this conversion page, even though I just care about the balancer #
http://www.atiracing.com/products/da...harger.kit.htm
8% OD – 7.960” Overall Dia, uses shell assy, 917107
I'm bored so was just trying to start a conversation.
yea, the whole 'shell #' thing is pretty confusing... took me a while to get mine ordered right
Good info.. thanks.
Got an IW with this kit, but prefer mine.. I will sell it.
#34
So your 7.96" probably = 7.77" drive diameter
I'd be curious what ATI says though.
#36
