New winter project.. going to need help from the experts !!
#41
I would never knock the eforce I had. Did what I want and had no problems with it in 4 years. I never faced the issues you don't like about PD's. I hope I get so lucky this time around.
#42
As long as the belt alignment is perfect, you will have ZERO issues.
#43
Ok... emailed ATI and asked what measurement I should use to calculate blower speed. Here is the response, which doesn't really help unless I know if I should use the damper size or the shell size. Simple question I asked them. Lousy answer.
P/N 917107 is 7.96 diameter which is 8% over driven.
I suppose this means I should this measurement, which is the shell size.
#47
You need to make sure you calibrate it over a long distance. That piece of paper it comes with is a joke. I used a extruded level and a granite surface plate to calibrate mine over 3 feet.
#48
I will. I read the sticky in the C5 section. Seems to be a good explanation. Thanks
#49
10% OD would be 8", so I would just go off their 8% OD and use that. So it probably is a 7.8 or so.
#50
Breecher, ATI basher is a good name, considering what the Procharger guy thinks of you. Wrong ATI though.
#51
Looks like 4", and yes, no issues. ECS and the newer A&A kits both use 4" upper now.
#55
Car has two of those BOV's, the other is in the stock A&A location under the headlight right off the blower discharge.. The Inlet is 4". The radiator is a shortened dewitts unit with a custom fan shroud I made, dual electric fans. Yes the stock hood fits. Everything would fit with the stock radiator with the exception of the 4" inlet pipe...
#56
You guys are very helpful, and I appreciate it.
#58
IMO, put the BOV pre intercooler core. You want to vent the air before it heats up the cooler. I got 1 tial on the U pipe where A&A puts there, and 1 on the bottom of the IC where ECS puts there. I think any Ysi spinning fast needs at least 2 BOVs. Now if you spin it slower, maybe 1 will do.
#59
#60
So then I will just mount the BOV where A&A does. Think it looks cool up top but want it to work as well as possible. What do you consider spinning it fast ?
