Any one running a ZR1 Map sensor?
Is anyone running a ZR1 Map sensor on the C6 Z06? I was wondering if using the ZR1 Map would be a plug and play or If it needed an adaptor and if so where to find it. When adding boost is is best to use the stock MAP or upgrade?
http://www.jdpmotorsports.com/genuin...ensor-12592525
Will this work?
Will this work?
