My F1-R build thread.
My F1-R build thread (RESULTS ARE IN)
Although my build is almost done, I figured I should do a build a thread for the hell of it. My car is a 09' Z that previously was at ~750whp with E85 and nitrous. The goal of this build is around 1000whp on boost and close to 1100whp with a small shot.
Main parts of the build.
Don't have a lot of pictures but here are some. Let me know what you think!
- LS7 Block with Darton wet sleeves - ended up being around ~431ci after the machine work.
- Callies Dragonslayer Crank
- Callies Ultra H-Beams
- Custom JE dish pistons
- Custom blower cam
- Katech High volume oil pump
- LS6 water pump
- ZR1 compressor and MAP
- Dewitts shortened radiator with dual SPAL fans
- Ditching LG 1 7/8 headers for 2" ARH
- Stock LS7 rockers with OEM intake and SS exhaust valves
- Ported LS7 intake manifold (sold FAST 102 for fear of coming apart and my NW 102 TB)
- Valve job with new guides. No porting.
- DP Big mouth intake
- Polished F1-R with 10 rib DD system
- 10 rib IW balancer
- Allstar performance custom breather system (bung welded on each valve cover)
- Adding a Magnafuel 750 on top of the existing in tank Walbro 450
- ID 2000s
- E85
- Nitrous
- Weld 17x11 RTS rear wheels
- M&H 325/45/17 Racemasters
Additions/Changes during build and testing. - Procharger "Race" tri-core intercooler
- Custom oil cooler setup
- RPS Triple Billet Carbon Clutch and ZR1 slave
- RSD 4pt roll bar with Crow harnesses
- Vi-King dual adjustable shocks
That's gonna be a killer car and not like it wasn't already. Looking forward to getting drug in March.
Supporting Vendor
Next is the head deck thickness and material. The thicker the material, the better chance you have of it not flexing (another obvious statement).
The head gasket is always a consideration as is prep.
The deck and head surfaces are often overlooked. Many consider the machine shop or factory finish of a head or block sufficient, when it is often not. I prefer to lap my heads with 400grit sand paper to get the roughness to an appropriate level. For the block, I have a large, flat bar that I use if I'm able. I won't do it if the block is together and I can't wash it thoroughly or at least turn the block upside down to prevent any grit from getting into the motor.
My apologies for the hijack.
Wicked build OP! Should be a real treat to stomp on people with.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
I'm sure I will cross paths with you and Detoxx again in Houston.
http://hinsonsupercars.com/p-473-arp...ls2ls3ls7.aspx
I am really curious to see the power curve on this car. Anyone have any guesses based on other builds here? Thanks everyone for the replies!
Sorry should of mentioned that. Aiming for 9.7:1
I am using this ARP kit. They are not the CA625s
Very nice. What valve covers are those?
Holidays slowed the build down of course but here is a updated picture while test fitting the piping.
This is just my uneducated guesses based off of my 2 years of experience running an F1R.
I'm sub'd for your updates and ofcourse your dyno numbers. Make sure to bring a velocity stack with you to the dyno and remove the filter/pipe.
The F1R with a 4.25"/8" pulley combo will come on hard, quick, then likely start to peter out around 6k, by 6500 your power curve will likely be dropping pretty hard. You will probably be hard pressed to hit 1000rwhp with the R, it will be very close...also depending on how aggressive you are on the tune and Ofcourse the rest of the combo. I could see it maybe hitting 1000rwhp very early on, maybe by 6k, then tanking afterwards.
