C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
AZ 1/2 Mile
Old 12-15-2014, 03:10 PM
  #41
ace32x
ace32x's Avatar
Originally Posted by Unreal
Yah, should have messed with the pressure more. That being said, maybe this runway was less grippy? In the morning I was spinning 4th until it warmed up. Shocks will be done for sure. Got DRM bilsteins. I'll swap to some ridetech or LGs asap. Already pulled car apart.
wasn't it damp in the morning? The dust pays a large factor too. Usually pretty dusty until some passes get made and blow it around.
Old 12-15-2014, 03:38 PM
  #42
dbs1vette
dbs1vette's Avatar
I was going to mention the dust. Certainly more of a factor in the far lane, but to me I still seemed to have less traction issues in the far lane as I think the moisture slipped over to the closer lane before drying out.
I also just packed the car and went. Left my spare and jack at home. Won't do that again, in fact contemplating buying my trailer back from the shop that works on my car. Just having a flat there with no spare was a problem. If I had something worse I'd have darn sure wished I had a trailer to get it home in.
Old 12-15-2014, 03:47 PM
  #43
turbotuner20v
turbotuner20v's Avatar
My DRM shocks worked great... I really think it's a pressure thing. My 17" M&H tires wore the middle ~8" of the tire out pretty bad aired up... you need them down around 15psi to get a flat contact patch.
Old 12-15-2014, 05:16 PM
  #44
Corvettinator
Corvettinator's Avatar
I'm sorry, but 170MPH+ on 15 PSI tires with no cage is cray cray.
I think I'll get an AWD car before I take up this hobby.
Old 12-15-2014, 05:31 PM
  #45
ace32x
ace32x's Avatar
Originally Posted by Corvettinator
I'm sorry, but 170MPH+ on 15 PSI tires with no cage is cray cray. I think I'll get an AWD car before I take up this hobby.
can't knock it till you try it. It's stable. And on another note the Vette frames are roll over certed to 200 mph if I'm not mistaken. Only car that doesn't require a cage at the silver state challenge in Nevada
With that said I still have a cage in mine. And a 10 point going in the other build
Old 12-15-2014, 05:36 PM
  #46
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
I rather not race than put a cage in. Drive the car around way way way way too much to have a cage in it.
Will definitely try lower pressure. It was perfectly stable at 20.
Old 12-15-2014, 05:49 PM
  #47
ace32x
ace32x's Avatar
I rather not race than put a cage in. Drive the car around way way way way too much to have a cage in it. Will definitely try lower pressure. It was perfectly stable at 20.
rsd cage isn't intrusive at all. What I have in the zr1 I wouldn't have put it in except most events make you have one over 190
Old 12-15-2014, 08:19 PM
  #48
Cordes Performance Racing
Supporting Vendor
Cordes Performance Racing's Avatar
Received 1,228 Likes on 775 Posts
Ya this runway was a different compound than Shifts3ctor for sure, next time people will be tweaking more i'm sure as this time it was like a kid in a free for all at toy'sRus. First time having this and we all went :will y:
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old 12-15-2014, 08:44 PM
  #49
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
Not sure that cage would do anything in a roll over. Look at where the main hoop bolts to in the Vette.
Old 12-16-2014, 10:26 AM
  #50
Unreal
Unreal's Avatar
Agreed with that. RSD cage looks more show than function.
Valve covers off and drilled, weld on fittings later today. Should have tensioner welded up today too.
Old 12-16-2014, 10:37 AM
  #51
Streetk14
Streetk14's Avatar
My experience on these type of runways at ~200 rwhp less than you has been that traction can vary by a HUGE amount depending on temp and runway prep. The last one I ran at it was close to 90 degrees out all day long and my car would dead-hook 2nd gear at 50 mph on RE11 street tires (with a little burnout and slight airing down of the tires). The runway had also been cleaned off with a street sweeper before the runs started.
The event before that was spin city through 2nd and 3rd, but it was a lot cooler and windy. The track also hadn't been cleaned by a street sweeper on that event. Same location and runway, though. It was so frustrating that I barely made any passes that day. But yeah, huge difference in traction based on those things. I can only imagine at 900+ rwhp. You have much better tires, but still.
Old 12-16-2014, 10:41 AM
  #52
Unreal
Unreal's Avatar
They didn't clean it, morning was wet and ~50F out, afternoon was mid 60s. I agree, I bet it would have hooked a lot better cleaned off and in the 80s.
Old 12-16-2014, 01:21 PM
  #53
ace32x
ace32x's Avatar
good enough for me combined with gm roll over testing
Old 12-16-2014, 01:52 PM
  #54
Unreal
Unreal's Avatar
I can see one to pass tech, but I doubt it offers much more than factory in terms of protection, so until I'm forced to do one to run an event, I'll stay factory.
Old 12-16-2014, 09:53 PM
  #55
gotjuice?
gotjuice?'s Avatar
St. Jude Donor '13
I can see one to pass tech, but I doubt it offers much more than factory in terms of protection.
Old 12-17-2014, 04:36 PM
  #56
EX1
EX1's Avatar
Looks like a ton of fun
I too would like more info on what suspension setups people are running for this type of racing.
Old 12-18-2014, 05:02 PM
  #57
SteveDoten@ARH
Premium Supporting Vendor
SteveDoten@ARH's Avatar
Nick, from all of us in NY, Thank You for posting the event coverage. Very cool pics here.
I know a lot of F16's from Luke AFB had sometimes used Gila Bend as an emergency landing strip.
Spent 4 years stationed our there, 94-98, best weather in the Nation
To AZ 1/2 Mile
Old 12-18-2014, 06:08 PM
  #58
Unreal
Unreal's Avatar
All the fast vettes were running ARH headers.
Old 12-19-2014, 02:08 AM
  #59
winters97gt
winters97gt's Avatar
Originally Posted by gotjuice?
I agree. Had one in my C6 just to bang gears and run 9's around 150mph in the 1/4. It's a death trap if the car comes apart at high speeds. Very nice fit and finish and great to pass tech with though.
Old 12-19-2014, 08:48 AM
  #60
Unreal
Unreal's Avatar
Quick Reply: AZ 1/2 Mile
