FI sheet metal intake manifold
Hey guys
I was searching for an Ls7 sheet metal intake manifold for my new TT build and have seen this I tank from Clpmotorsports
Check the link
http://www.clpmotorsports.com/Ozmo-Engineering-Ls7-Sheet-Aluminum-Intake-Manifold_p_693.html
Have anybody tried it? I need opinions
Check the link
Hey guys
http://www.clpmotorsports.com/Ozmo-E...old_p_693.html
-Curtis
I liked the price and design of this intake but I wanted to see if someone tried it
If your going to spend that much on an intake you might as well get one from John Marcella.
http://www.marcellamanifolds.net/images/Images.html
I'm cutting mine but I guess it's personal preference. Hopefully someone comes out with an affordable low profile LS7 cast version that can fit under the hood.
Supporting Vendor
Not sure if this will fit, but it sure is a lot less expensive than the comparable ones I've seen in the past, by a mile.
http://www.ebay.com/itm/SLP-FABRICAT...-/251764943371
These cheap ones probably made in china. I can tell you that the finishing inside was not impressive on the ones I actually saw at SEMA. The photos of the one you posted look better.
