C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
1700HP TT Glide 9" C6 Z06 Build
Old 03-29-2015, 11:24 AM
  #121
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Not much to say except .... WOW..... good luck with this very impressive build.
Old 03-30-2015, 12:53 AM
  #122
inspector12
inspector12's Avatar
Good meeting you I love that **** so I can put a face with a name etc... Car sounded good in person bro. We will have to meet up again. Did you get the stuff figured out at the race track that day I saw you there with the car jacked up? I know you said it was minor. Seemed like there were a ton of us trying to sort out minor things.
Old 03-30-2015, 12:00 PM
  #123
dascorcha21
dascorcha21's Avatar
it was a pleasure man! same with your docile beast! yea we got it fixed monday
Old 03-30-2015, 06:55 PM
  #124
gmtech1234
gmtech1234's Avatar
Why was the car suspension pulled down for the alignment?
Old 03-30-2015, 10:03 PM
  #125
SHovV
SHovV's Avatar
my guess is to simulate the load of acceleration and weight transfer
Old 04-02-2015, 02:03 PM
  #126
HoustonSVT
HoustonSVT's Avatar
Did you paint the side skirts yourself? If so would you mind sharing your prep and paint process?
Old 04-04-2015, 06:02 PM
  #127
dascorcha21
correct!
nope i leave that stuff to the professionals
Old 04-12-2015, 06:24 AM
  #128
fe9_fe9
fe9_fe9's Avatar
Originally Posted by dascorcha21
Pulled from my ls1tech thread
The 2 step works just like any other 2 step.. in this particular scenario its pretty much a plug and play affair. As you can see by the interior pic theres a huge red button in place and 2 other smaller rocker ones... in order to avoid driving down the rd or highway and accidentally engaging the TB one of the rockers arms it. without the arming switch engaged that big red button does nothing.. the other rocker switch engages the rolling anti-lag which in essence i am engaging the 2-step via the switch to be able to floor it in the car and build boost all while holding rpm/mph at the specified rpm until the button is released and the car enters the stratosphere... hope that helps you understand it.
Props on an amazing build. You should be very proud
I would love to see of some rolling anti-lag action in video
Old 04-22-2015, 04:30 PM
  #129
dascorcha21
tks man, dont have any anti lag videos just a couple of test pulls on gates so far...
Old 04-23-2015, 12:45 AM
  #130
Tuomas FIN
Tuomas FIN's Avatar
Got any dyno results?
Old 04-23-2015, 02:27 PM
  #131
dascorcha21
no dyno probably wont have any for some time..
Old 05-05-2015, 02:23 PM
  #132
dascorcha21
Went to the 1/8 mile last weekend, prep wasn't great but coming off the line footbraking i was able to bring the boost up to 8lbs at 90mph until then i was at 4lbs (gates) this was my slip.
Old 05-05-2015, 03:16 PM
  #133
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
What's that roughly for the 1/4, mid 9's?
Old 05-05-2015, 06:34 PM
  #134
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Killer mph for only 8 psi... That's about 850 rwhp to run that mph.
6.24 converts to 9.73 in the 1/4. Obviously a prepped track and 275 Pros is a must.
I can't wait to see it turned up. Did you ever get it on the dyno?
Old 05-05-2015, 06:44 PM
  #135
Arctic Vette
Arctic Vette's Avatar
Sick build!
Old 05-06-2015, 01:40 AM
  #136
dascorcha21
time wise mid 9's
but MPH wise 8 somewhere in the 8's.
this was my slip when i had nitrous on the car on a 100 shot.
notice i went 114mph in the 1/8. On 4lbs till 90mph and then 8lbs till the end of run i went 123mph. That should give you a good indication of where the car sits
Old 05-06-2015, 02:55 AM
  #137
dascorcha21
Here is some footage of some of the Testing we were doing and gathered.
To 1700HP TT Glide 9" C6 Z06 Build
Old 05-06-2015, 08:36 AM
  #138
BLOWNBLUEZ06@RKT Performance
Supporting Vendor
BLOWNBLUEZ06@RKT Performance's Avatar
Didn't anybody tell you??
You're supposed to do the burnout BEFORE you stage.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Old 05-07-2015, 09:11 AM
  #139
dascorcha21
Lol
Old 05-08-2015, 06:17 AM
  #140
WHITE_SHARK
WHITE_SHARK's Avatar
congrats on the 8 second pass!! amazing setup indeed and sure this will be 7 second on max boost
Quick Reply: 1700HP TT Glide 9" C6 Z06 Build
