1000RWHP-1200RWHP Weld 15 or 17 pics of setups
02-16-2015, 08:42 PM
Quote:
Originally Posted by
turbotuner20v
18x6 fronts
I like the blue, so I don't have any plans to wrap the roof or halo
How is that setup coping with your newfound 1000whp?
Good call on the roof! Too many people doing that. Makes the car look like a 4th gen Camaro roof
02-16-2015, 08:59 PM
There's 3" of snow and its 13* outside. I'll tell you in a month after tx2k
02-16-2015, 09:05 PM
turbotuner20v
Wish you luck
02-16-2015, 09:14 PM
St. Jude Donor '15
turbotuner20v
What state are you in?
02-16-2015, 09:50 PM
schpenxel
Kansas city
02-16-2015, 11:31 PM
turbotuner20v
there's 3" of snow and its 13* outside. I'll tell you in a month after tx2k :d
racecar!!!
02-23-2015, 02:24 PM
yur2slo
15's in the back - have skinnies to match in the front but this was at the Ocala 1/2 mile race
You're running C6 Base rear brakes to run 15's correct?
-Curtis
02-23-2015, 04:08 PM
C6 Curtis
-Curtis
Yes - had to grind down the calipers some as well
02-23-2015, 04:42 PM
I'm about to buy spindles. I have bigger Z51 brakes. Do I need C5 kit or can grind? Please only respond if you have exact answer. Thanks.
02-23-2015, 04:53 PM
04gtogoat
You can use your caliper, but you need the base rotors (either C6 or C5) and the caliper mount bracket (C6 base or I assume C5 base?)
I have the Z51 calipers, C6 base bracket, C5 base rotors and I still had to grind a lot out of my calipers
02-23-2015, 07:23 PM
turbotuner20v
It also depends on which wheel you get. I had the racestars and had to only grind the ribs off the caliper. When I switched to the weld rts I had to grind a lot more off the caliper and lower control arm.
02-27-2015, 06:43 PM
For the ABS light not to trip does the rear need to be taller/higher than the front or vice versa? Thanks.
02-27-2015, 07:20 PM
04gtogoat
You need to maintain the same ratio of front to rear diameter
04-11-2015, 07:35 PM
Maybe yall can help me out. My 03 Z06 currently has C6 Z51 brakes whats the smallest wheel I could run?
04-12-2015, 11:31 AM
Atrain59
You would be able to clear a 17. Call weld I'm sure they can point you in the right direction
04-16-2015, 12:07 PM
Slo-Poc
17" weld RTS do not clear the caliper with Z51 brakes.
04-16-2015, 12:48 PM
They should. If a 17 clears z06 brakes that are much larger, then just the right offset should easily clear a z51 caliper.
04-16-2015, 01:50 PM
different 17's for base fenders vs. z06 fenders
02-14-2017, 09:50 AM
Bringing this back to the top to see if anyone has any new pictures of 15 inch setups.
02-14-2017, 11:11 PM
