1000RWHP tire advice
What are all you 1000+rwhp guys dong for rubber? I am looking something for roll racing/ standing mile. Not much drag stuff. I am open to 15"-19" wheel suggestions.
15's would be your best bet but if you don't want to do spindles etc. 17's at a minimum. M/T ET Street or M&H Racemasters.
I have the same question too so I'm glad you got the topic going. I was wondering why a 15" rim with a taller profile is better than a 18-19" rim with the lower profile if the tire is just as tall and wide?
More meat (sidewall) to absorb the power. At 1xxxrw you want the most sidewall possible.
I run 18 345 ET streets daily, and 15" 325 ET streets for events. The 15s hook MUCH better. Best traction is a 275 15" ET pro, but they wear out quicker than the 325s.
im hooking 1100 wheel on my 345 35 18 et street 2 mickeys at 40 on the road very well on my zr1. weight transfer on the stock soft shocks help a ton on the mag ride though.
planning on running the new 325 50 15 street R mickey on my z06 when they release this summer though. they look like the new tire to have
For those of you on 17's, do you prefer the 315/35R17 or 335/35R17 M/T & Hoosier DR's which are around 25.6" tall or the 325/45R17 M&H DR's which are 28" tall? I am currently running the 335 Hoosiers and am curious if switching to the taller 325 M&H would result in negative performance due to the greater rotating weight and height or greater performance due to increased traction from the larger roll out area? The 335 Hoosier has the widest contact patch and is the lightest drag radial, and the M&H is the tallest and heaviest option but will have the better gearing for high hp applications.
tire life is alright. I don't expect a ton of life out of them. this last set I got a 2 day air strip event out of them (with about 13 burn outs) and 3k miles out of them.
I opted for the 325 M&Hs this time around as I wanted a taller tire and to get the most I can out of each gear. I would go this route personally with the amount of torque your big nitrous setup is making.
After "oversized" shipping charges, American Muscle had them cheapest at $606 shipped. Jegs and Summit are close to $630 shipped.
My first heat cycle will be the burnout box before my first run at TX2k haha
