Rear mount turbo build
Midnight98ws6 (07-23-2022)
I sold my 7175 to my buddy with an ls1 c5. Ill be building that kit after I finish mine and a turbo fox. I think his is going to spool at idle haha
Is the exhaust going to be dumped or will you make an exhaust like tip to finish it off? I'm sure the turbos respond better to as little backpressure as possible, but I like the finished look of tips.
-Curtis
#34
I made a bracket for the pump which will be powder coated crinkle black along with the compressor cover, and the visible intercooler piping. I changed the wastegate location. The dump will be changed.
#36
Decided to go under the subframe with the ic piping instead of through it. Ovaled it with the lift and a 4x4 haha. Ran out of material to mount the intercooler :/
#38
Sweetness! Can't wait to see some results, I've been looking at doing something very similiar but with an S475, I'll be very interested in how well the 480 spools. A quick question, do you think there would be any way to finagle in a muffler in the rear with the turbo mounted all the way to one side? I like my cars quiet so really would love to stick a muffler in there to keep it quiet as possible.
#39
#40
End result would be 650whp ish, really just would like a very fast spooling setup, I've had turbo cars in the past and played with different turbo sizes, and a smaller fast spooling turbo is way more fun on the street than a laggier big turbo. Never messed with a rear mount setup before and there is limited info on 6spd cars with rear setups that I could find. Your's will be the closest setup to the one I'm going with even as far as I was going to go with the spinmonster cam if I did cam first.
