Build V2.5
#363
Na, just been cruising around on the few non-rainy days we've had here. It's actually been kind of fun having the 19/20" r888 setup on to take it through the twisties and still stick 3rd gear from 60mph. Just have to run slower cars... my buddy's 870whp gtr was a pretty even race actually.
I'm picking up a cam from tooley to install mid July
238(qxx)/259(huc) .643/.632 115+5
#364
#365
Engine builder went a little different direction with his cam recommendation:
240 (XTRM) / 258 (LXL) .615/.615 116 + 5
I'm far from a cam expert, so anyone here have thoughts on how that compares to the Tooley one:
238 (qxx) / 259 (huc) .643/.632 115 + 5
#366
Just my opinion since I'm not a cam expert but know quite a bit after exchanging emails with Martin@Tick.
#367
Here is the breakdown of events.
Your builders cam.....
IVO 9.0
IVC 51.0
EVO 70.0
EVC 8.0
17* overlap
Tooleys cam....
IVO 9.0
IVC 49.0
EVO 69.5
EVC 9.5
18.5* overlap
As Pitufina said, most of the difference is in the lobe profile. Which can be splitting hairs if your not pushing the valve train hard (7000+rpm or heavy valves...etc).
IVO 9.0
IVC 51.0
EVO 70.0
EVC 8.0
17* overlap
Tooleys cam....
IVO 9.0
IVC 49.0
EVO 69.5
EVC 9.5
18.5* overlap
#369
#370
#373
Tooley's cam will have smoother lobes. Thise lobes are mostly designed to be light lift. I wouldn't be concerned. I personally would use Brian's specd cam.
#375
