Build V2.5
#163
Looking good. Quick question. Is there any advantage /disadvantage to placing the BOV where you have it. Don't usually see it there. I may consider adding a second one and that looks like a good spot space wise.
#164
It's an easy spot to add a 2nd one, but it can disrupt the part throttle maf signal if you have too light a spring. I'm running the 11psi spring to keep it closed at part throttle
#165
Thanks. That's what stops me from putting one up top on the pipe. It looks cool but messes with maf too much.
#166
She's alive again and all seems well.
RSD radiator fittings for trans cooler were loose (not screwed in tight, quick connect fit fine) so I had a little leak there. Not sure if all of their radiators come like that, so be sure to double check before installing since the top one is hard to reach with the blower installed.
Going to put some miles on it this week and dyno next Saturday.
#167
how much louder is the X over the A?
#170
#173
Looks killer man!
Whatever you do...don't forget to bring the velocity stack/5" pipe with you to the dyno.... Youre definitely gonna want to dyno it with the stack on it.
Sub'd for the numbers.... I'd love to see you make 1300+..
#175
So about the hood fit... it's so close a piece of double side tape sticks. I marked a black dot where it's probably going to rub a little bit. Closes and latches ok tho.
#180
Received 1,193 Likes
St. Jude Donor '15
Clearance is clearance I suppose
