ECS install question, Evap lines/Z06
I'm about done with the install. The instructions done realty say much about what to do with the eVap and breather lines from the dry sump.
Do I put them all back in the stock locations?
Om the pass side, there is no prevision in the intake tube for the one line. The other line has no place to go if I run a line from the air filter to it as instructed.
Can some one post up a pic or a diagram as to best solution. I'm running stock cam, intake and only mods is the blower.
pass rear
pass front
pass front
drivers rear
pass rear
pass front
pass front
drivers rear
Received 1,194 Likes
St. Jude Donor '15
You do NOT have to pull the steering rack to pin the crank. Look up the magna charger instructions and they show you how to do it. Basically lower the front cradle as far as you can while leaving the nuts on the bolts.. raise the engine as far as you can, and you'll end up with enough space to pin the crank without pulling the rack. You'll need a right angle drill of some sort to fit in the space you'll have to work with
I started it in December. I pulled the heads and sent them out. I work on it one day a week end when I have time. No rush. Haven't tuched it in 3 weeks. It's ready to fire up.
Leave sump stuff stock.
Leave evap stuff stock.
The one line you are asking about, can T it to the air filter line, or run it to intake manifold after a check valve, or vent it.
Because they are for a wet sump car that doesn't have any of that. Just needs to be hooked to a vacuum source if you want to keep it more emissions friendly, or you can vent them.
Just call your dealer or ECS if you have any questions. They are very helpful.
I would like to not smell the oil from venting under the hood as the cabin filter is about 6inches away from the dry sump. Also if I attatch it to the intake I will need another check valve so I don't boost the lines and pressurize the system. I'm sure everyone dose something, just not trying to re invent the wheel. I will call today and ask what's best for a street car.
My vent and catchcan is right by there, no smells at all.
T it into the line after the check valve, then no extra check valve needed,
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
On a stock C6Z with a supercharger there is no need to go crazy with the PCV system, the only difference with the std C6 vrs the Z06 is that the dry sump is in between. Here is a pic for you which will be added to the instructions. No smell or problems with oil unless you overfill it. Thank you.
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
Awesome Doug, Thank you very much. I get it now. Every thing go's in the stock location. The one tube with no were to go from the air intake ,go's to the line from the new filter. Basically same location in the system, just has to be moved so it is before the blower.
Do I run the stock caps or add the cap with the breather built in that came with the kit, and put in on top of the dry sump? So the system can vent under boost I take it.
I do not feel it is necessary until you go higher on the HP/boost.
Thank you again. I should be all set then. I will run it sealed and keep the cap for future expansion.
I will call you in a week or so. I may just bring the car to you for the tune. I'm jest east of Cleveland Ohio. It's about 7 hrs but I can't think of anyone to tune around me that I feel all fuzzy about. I may just see if you can install a meth kit and tune it at the same time.
Set everything as Doug said. Car fired right up and idled up to full temp. And the belt alignment looks to be spot on. Now to wire the boost-a-pump when I get time.
St. Jude Donor '15
St. Jude Donor '15
I also used a hobbs switch with a metri-pack style connector if you're into that kind of thing. Racetronix sells them as well. The one ECS includes will work fine, I just prefer to use metri/weatherpack connectors and thought they looked a lot neater. I think I ordered the 4psi one. They are adjustable, so it's not a huge deal which one you order as long as it's in the ballpark
The harness def. made the BAP install easier + had the obvious benefit of bigger wiring going to the fuel pump all the time. And that way you can put the BAP in the rear driver fender well instead of trying to put it under the hood where space is obviously limited
You'll need to add one wire to the racetronix harness (or just zip tie it to it or something). This is for the trigger wire that turns the BAP "on" when you're over a certain amount of boost.
