C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
14mm Fuel Rail Spacer
Old 03-04-2015, 12:03 PM
Kerns
Kerns's Avatar
Default 14mm Fuel Rail Spacer
Getting some ID1000 injectors and need the 14mm fuel rail spacer to put them on, but I have no idea where to get these at. Any suggestions?
Old 03-04-2015, 12:14 PM
breecher_7
breecher_7's Avatar
Get me the dimensions you want and Ill make you a set on the cheap. You are just talking about a spacer that goes between the intake manifold and fuel rail mounting tabs to push the rails up correct?
Old 03-04-2015, 12:25 PM
Kerns
Kerns's Avatar
That is correct Breecher. No idea on what size I need other than it needs to be 14mm tall.
Old 03-04-2015, 12:55 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Just goto a hardware store, get some spacers. They should have them there, or close enough to grind/shim.
Old 03-04-2015, 01:39 PM
Turbo-Geist
Turbo-Geist's Avatar
2017 C5 of Year Finalist
Are you using the base ID1000 injectors without the adapter hats? I just made some spacers for mine.
I'm using these ID1000 injectors
I made some spacers that were 0.550" tall out of aluminum round bar. You can also buy nylon spacers at Lowe's that already have the hole drilled and are 1" in length and then cut them to the proper height.
The other option is to buy the spacer kit that Katech sells.
Old 03-04-2015, 01:51 PM
Kerns
Kerns's Avatar
Correct. It looks like the spacer kit that Katech sells is for LS1 style injectors on an LS3/LS7 and I believe those are 60mm in length.
Old 03-04-2015, 01:58 PM
breecher_7
breecher_7's Avatar
6061 Aluminum...
I am having a slow day....
Old 03-04-2015, 02:06 PM
Kerns
Kerns's Avatar
OMG! You're amazing Breecher!
Old 03-04-2015, 02:09 PM
breecher_7
breecher_7's Avatar
That is what the women tell me...
Old 03-04-2015, 02:13 PM
Kerns
Kerns's Avatar
LOL... Do you commonly mistake the name "Oh Jesus" for your own because of hearing it so often in the bedroom? Also, what do I owe you?
Old 03-04-2015, 02:16 PM
breecher_7
breecher_7's Avatar
If my head gets any bigger, I wont fit through the door way...
Owe? Who said they were for sale! Maybe I just decided to make them because I was having a slow day and wanted to see if this is what you were looking for!
They even have Grade 10.9 hardware with them!
Old 03-04-2015, 02:27 PM
Kerns
Kerns's Avatar
Noooooooo!
Old 03-04-2015, 02:34 PM
breecher_7
breecher_7's Avatar
Noooooooo!
Shoot me a PM... Ill get them shipped out.
Old 03-04-2015, 04:31 PM
rob20rx7
rob20rx7's Avatar
Great Guy! awesome forum!
Old 03-04-2015, 04:52 PM
Unreal
Unreal's Avatar
Except if the OP was running a PD blower, Breecher would have told him to screw off.
Old 03-04-2015, 05:59 PM
breecher_7
breecher_7's Avatar
To 14mm Fuel Rail Spacer
Quick Reply: 14mm Fuel Rail Spacer
