Another LS3 getting blown
#342
Best times on the old setup
I've been playing on the original mods for about a year now and have whittled times down to a best of 10.43!
<br >
<br >
#343
Received 1,193 Likes
St. Jude Donor '15
#344
<br >
Back to FSP for bigger injectors, more boost and a stall converter.
#346
I'm currently restricted so that will be coming out to raise boost along with a ECS stage one fuel system and id850 injectors. A 3200 stall converter should help with the mundane 1.80 60ft times.
#348
I stuck some 19" Mickey DR's on stock rims and they work very well at the 2 tracks I primarily use. They both do a great job prepping the track and traction has never been an issue. (especially with a stock converter) LOL
#349
Originally Posted by 09harleyrider
Thanks! She does get movin once the boost hits but those lazy launches on the stock converter are killing ET's. I see a few guys getting into the 9's with a good stall converter. With any luck I can get there as well.
What size front tires are you using? I know the mickeys are 27.44 in diameter which is about half an inch taller than stock. It's "supposed" to throw off the active handling and TC.
#350
The hp is definitely there! I had a 3000 stall on my c5. You'll like it. Anything was better than the stocker.
#351
8th Gear
CUT LOOSE DA BOOST! My '08 got its first start today....that whine sounds soooo awesome. Should get her back in a week, 10 days after major 2 map tuning. She's A6 w/meth also.
Exciting, aint it? Keep Cool and Boost On....
Facebook Post
#352
https://www.facebook.com/CorvetteCon...nch_main_video
#353
8th Gear
Cut loose da boost!
