Billet Alternators with new pricing
#41
I would think the 240 amp would have more winding's in it (ie heavier) which would put more demand on the belt as well.
I can idle at 800 rpm with all lights on and dual spal fans on hi and it still holds 14.5 volts.
.02
DJ
#44
Well only on a need to basis, more windings might be heavier to spin but essentially amperage is on demand, so if your car only needs 80 amps to run whether you have a 240 amp or 120 amp alternator the demand is still 80 and the alternator will only put out 80.
I might go with 170 we'll see
#45
Supporting Vendor
No reason whatsoever. It's overkill and added cost to boot. If you can't justify it with electrical load, then it's not recommended. You'll hold the same voltage between the two until your load becomes so great that the 170 can no longer sustain it. It is rare that I recommend it. The TT cars with scavenge pumps, extra fans for trans and oil coolers and things like that would make me start to recommend the 240
Are these alternators harder on belts? I'm running an A&A secondary drive like one of the pictures which runs off a 4 rib belt jack shaft. Considering that this alternator puts out 240 amps how much tougher is it for the belt to spin compared to stock? Or not at all.
Thanks!
Thanks!
I have the 170 amp alternator on my car that has the A&A Secondary drive. No belt issues. I have belt slip issues when using the AC on but voltage holds steady at 14.5 volts. I use my car for drag racing and always log the bat voltage with no issues with voltage drop.
Bigger is not always better. The 170 amp puts out more amps at lower rpm than the higher amp versions.
DJ
DJ
#49
Supporting Vendor
Supporting Vendor
Free bump for BLOWNBLUEZ It shipped a lot faster than expected! Prob delivered in 2 days or so..
#54
I thought he shipped mine so fast because I ordered it on my birthday LOL! I got mine today and it looks so beautiful I decided to let it sleep in my bed tonight. I hope it knows we have to get up early in the morning for install.
PS. Don't make fun of my sheets
#55
I guess as long as you're not sleeping with your "tranny" you should be okay with just an "alternator" in your bed!
These things are real eye candy and it sounds like they work as good as they look!
I think I'm going to order me a black one soon.
#56
Supporting Vendor
Don't get me wrong. I wear the pants in this house.
She just tells me which ones.
Let me know when you're ready. There's currently roughly a 7-10 day wait.
#59
Supporting Vendor
In stock, ready to ship.
Thanks for your orders.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
#60
I installed my alternator this past weekend and could not be any more pleased with the technical support and quality of the product received. I had the alternator on my door step within two days of ordering.
Background:
In the Alabama heat with a "full" load on the charging system I would often times get the annoying check charging system message.
I have a high dollar forged longblock with a rowdy cam, ATI dampner, and a considerable amount of engine bay heat. I went with a reman from O'Reilley when the OEM alternator died. The reman would make it for 3-4 days and crap the bed at inconvenient times. The average voltage output on the remans and the OEM peaked at 11.5 volts with high beams, fan, AC wide open, and the car at operating temperatures. It was common to see 10.x values on most days.
After the installation of this alternator I've got a rock solid 14.6-14.7 volts at idle and at cruise. Additionally, my inside and outside lights are brighter, my nitrous solenoids and supporting hardware have consistent voltage, and my standalone fuel system is getting 14+ volts as well.
This could very well be one of the best mods for any car regardless of modifications or purpose.
Check out the pictures below:
Note: The finish on the alternator is machined. The odd coloration in the pictures is condensation from the 67* temperature in my man cave to the 100*F and 85% humidity garage.
Thanks again for the great product!
Background:
