Thoughts on this setup (still keeping stock shortblock)
I'm at the point where I want more power. The car is an A6, so I will definitely be rebuilding the transmission and get a stall for the setup I go with. I've talked to some big shops from here and many don't seem to be against keeping the stock shortblock even with what I had in mind. I guess it's a matter of luck lol. Money isn't an issue, so if the shortblock decides to go then I'll rebuild it. The car's current setup is the ECS 1500 kit, ECS small blower cam, 1 7/8 headers and meth. At 13psi, the car made 724/622. Here's what I had in mind:
-TFS 255 heads
-Custom Pat G or Tick Performance cam
-Built Century 6L80E w/ FTI converter
-ECS fuel system and bigger injectors
-Upgrade lifters, trunion upgrade on rockers, ls9 gaskets, ARP head studs
-Use dual nozzle for meth
Tuning of course will be key to this so a reputable tuner will be sought for this. Any thoughts, ideas, or suggestions?
-TFS 255 heads
I pretty much have exact setup you have. Ecs built car 1500, baby blower cam, methanol, long tubes, century built 6l80 etc. Put down 780rwhp. I'm contemplating doing a engine build. Id like to do a 416ci or a 418ci. I'm curious why you're switching cams?
Money might not be an issue, but if you do a good job blowing up the motor with more power, which you will, you can take out your heads, block and even supercharger all at once.
Swap now, forge your stock bottom end, have the tranny built, and run a standard Paxton 2200 and make an extra 100hp. Or add a 2200r and add 150+hp.
I'm going to keep my options open as I am more than likely going to add a converter. Also with the TFS heads there will be better ptv clearance so I wouldn't mind exploring my options on a cam. A 416 is something I've been looking into as well. But I'm sure upgrading the head unit will be must to get some power out if it. What are your thoughts on your Century transmission?
