No Power Steering Cooler with ECS Kit??
Well, I just found out you lose your power steering cooler when installing an ECS S/C kit on a LS7.
What are my options? What is the majority of ECS LS7's doing?
What is the negative of not having a PS Cooler? This car will not be hot lapped or circle tracked/autox. It may be driven 3-4 hours at a time on road trips, and used for some roll racing.
Received 1,194 Likes
St. Jude Donor '15
I removed mine.. LS2. Made things a lot easier to work around.
If I remember correctly base models don't have power steering coolers anyways, so I figured it wasn't that big a deal.
St. Jude Donor '15
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Actually the brackets are for the oil cooler, The PS cooler can be eliminated as long as the car is not road raced, or the cooler can be mounted a little over to allow the duct to pass threw.
Took it off, never looked back. Unless you are doing 30+ minute hot lap sessions not an issue. Base corvettes dont have them.
m60gov20 (10-22-2022)
I did an Expedition cooler just like pictured above on my car and run Redline power steering fluid. Haven't had a chance to do any track days yet but I'm pretty confident it will be ok as long as the fluid level isn't too high.
