qhats the most compression c6z on 93 octane
04-02-2015, 06:54 PM
12.1 wiseco pistons prc 285 heads is this combo able to run pumpgas?
04-02-2015, 07:00 PM
yes, adjust spark advance
04-02-2015, 07:30 PM
Would it be safe to run a meth kit and pump gas? I plan on spraying the car with a 200 shot. I'm going to get a dedicated fuel cell for the nitrous.
04-06-2015, 12:48 PM
I'll look into upgrading those pistons before doing a 200 shot
04-06-2015, 02:08 PM
My compression is in low 12s on one of my cars. I run it on pump
Hasn't blown up yet.
04-06-2015, 08:09 PM
There's a lot more to a combination than static compression. It's more how the combination works together than it is individual pieces.
What are the full details on your build?
04-06-2015, 10:01 PM
Quote:
Originally Posted by
Turbo2L
Yep.... that's where dynamic compression comes into play.
04-07-2015, 12:20 PM
It depends on the valve events. I would not try to run something like a Katech torquer 110 at 12:1 on pump gas. Cams on the larger end of the spectrum would work.
05-16-2015, 03:54 PM
Wiesco +2.5 pistons PRC 285 70cc chamber heads, Fast 102, Btr stage 4 cam, innovative ballencer, stock z gasket
05-21-2015, 11:53 AM
240/249 110+3 lsa. 12:1 compression heads. 100shot = 730tq at 4500rpm
this was on 93oct.
