The New Build Begins ... finally
#61
Received 1,193 Likes
St. Jude Donor '15
#62
Motor install is pretty close to being complete. Added fluids, mounted most of the components.
A/C tensioner plate for O/D Balancer along with Stage 1 fuel kit finally arrived from ECS
Now I can button up the last bits and pieces and crank up her up sometime this weekend.
#64
Keep us posted.
#65
I really like this kind of stuff
#66
I Added an external cooler for the transmission shortly after adding the ECS kit. One of the best mods I or anyone else, with an A6, could do for it.
Engine oil temps was something I wanted to address while i had the car down. With the passenger side nose of the car housing the transmission cooler, I decided to place an engine oil cooler in the nose of the drivers side.
The nose area behind the bumper cover has a nice size occupancy rate, lol. It's premium real estate
By "us" you mean, you, I and Schpenexel, right?! (just kidding - sorta - I'm sure there has to be 1 other soul interested in this thread).
#67
I even see my buddy ScottG on here now. He's one of us Heartbeat guys that are an even rarer breed!!
What I really want to know is, how much of this work is actually yours, and how much is actually your better half's doing??
#68
Very nice looking work and smart to put the coolers. I have them in the same place and they help a lot, especially for the tranny. Since I never use them, I went a step further and replaced my fog lights with grills. Ton more airflow to the coolers that way.
Keep up the good work !!
#70
#72
Damm fine bunch of goodies you got there. And yes Tom we are a rare bunch. But love to see others spend their hard earned cash.
#73
St. Jude Donor '15
Looking good though. Hopefully she starts right up for you!
#75
St. Jude Donor '15
#76
consider putting some heat shield on those oil lines where they will be close to the headers. Better safe than sorry.
The side panel idea is not mine alone - I looked at what Pat G had done. Then after looking at front of the car – its a no brainier type of thing. It just makes sense on it improving airflow thru the intercooler/condenser/radiator. Its not a hard modification but it was time consuming and requires having a few metal working tools (grinders, cut off wheels, welding machines for both aluminum and steel ).
#77
Very nice work and thread. I can vouch that when you take your time, use the right stuff, and do things right, it pays off big time. About 1000 miles now without one issue to date, which from what I read seems to be rare with new, in depth builds.
Yours should be awesome with such attention to detail.
#78
Build looks great!
Btw, if it is slow to build oil pressure after start up, it's because the way you have the oil cooler mounted, the oil from the cooler will drain back into the pan, therefore you will have to refill the oil cooler after every start up.
If you mount it with the fittings on the top, it will not drain empty. Just FYI.
Good luck on the final product. It's gonna turn out great.
Which ERL shortblock did you get?
#79
You Sir - Are Da MAN!
I was kind of concerned with placement - but with the size of the cooler, I was limited on how I could mount it and still get half decent airflow across it. I was pleasantly surprised when I started it up last night and the oil gauge hit 50 immediately. That is with straight weight 30 VR oil for break in. I'm running the recommended Melling 10296 with the Red Spring still in it.
#80
Start up Video
I mean, since everyone else adds one to their thread
Last edited by M M Alexander; 07-21-2015 at 10:44 AM. Reason: Loads on Ipad - not on PC with YT tags?!?
