Braided oil drain line
Just got home. Police evacuated my neighborhood because of a local fire.
Can you post the fitting sizes and types you used? I'm not experienced with them.
Thanks,
Larry
Thanks,
Larry
I think he want a line to drain the self contained unit. Not the return line to the oil pan.
I would check with A&A.
Oh, then I misunderstood.... I don't know what you need for that. Not sure why it would need to be braided.... any rubber hose and fitting would do for that.
It was my impression that the self contained units had a remote drain line with a twist type feature that allows the oil to be drained.
Sent from my HTC One using IB AutoGroup
I've got a ProCharger and had a local hydraulic shop make up a braided line with the proper fitting at head unit and a small ball valve connected for quick drain.
10 years ago, We just used a syringe and sucked the oil out the fill hole. I think Andy started using the drain line out of braded hose.
