Upgrading fuel system on my 2009 FI Z06, going with Aeromotive Stealth intank set up
Can't wait! Doing a bunch of other stuff at the same time so it will be quite the project,
RXT clutch and bearing replacement
Remote bleeder
Hinson driveshaft with couplers
HMS Engine mounts
HMS Trans mounts
Complete fuel system
ECS trans and diff brace
Remote bleeder
HMS Engine mounts
HMS Trans mounts
My ECS brace just arrived yesterday also.
Received 1,194 Likes
St. Jude Donor '15
Good to hear you changed direction a little bit. It will be for the better in the end..
I haven't heard a bad thing about the Fore setup yet... too bad they have to go in the fuel tank, it's a beautiful piece!
how are you going to run your fuel rails? Series or parallel?
I like the idea of running them in parrallel with a crossover line in front but thinking if its going to be an issue with the firewall and driver side fuel rail and having to place that y block somewhere.
For either of your power levels, series is not even close to an issue.
The drivers side rail is very tight. Turbotuner suggested an Aeromotive banjo which is what I used and it fit well. I have my Y block in the fender.
https://www.corvetteforum.com/forums...tem-build.html
