vented oil fill cap
Received 1,260 Likes
lots of ways to skin this cat, my preference is minimum -10an fittings on the valve covers, run lines from valve covers to a breather can, and eliminate the pcv system and vacuum line to the blower inlet... that will allow it to breathe while also preventing oil vapor being ingested back into your intake... some people seem to like the cans mighty mouse makes and there are other ways to do it, comes down to personal preference I guess
Jeremy if you don't want to spend the cash right now on a MM set up (I would suggest it) I have my vented oil cap sitting around that I'll give to you to get you by.
Mightymouse setup and be done.
Yes you'll want some way for crank case pressure to vent. I'd suggest the Mighty Mouse draft or PCV can for your set up. Use the -AN fitting oil from MM and run a line to the catch can. Pretty easy.
