Calling ALL Nitrous Users & Abusers!
Hello!
I am getting ready to install a NX Plate Kit on my C6Z. I would like to see some ideas where you mounted your bottle, TPS/RPM Box & Timing Controller if you have one.
Pictures would be great, appreciate it ahead of time!
Do you have any helpful schematics on wiring up the noids, controllers and the FPSS?
Anything would be a help!
I put mine in the glove box. Its one of those things you set once and shouldn't have to mess with it again. So you can put it anywhere.
The Bottle I mounted in the trunk passenger side close enough where I could turn it on from the drivers seat
Pm me if you have any questions on the install, Ill be glad to help.
Did you run a positive and negative wire from the battery all the way to the front or did you pull positive and ground from somewhere under the hood?
Instructions will come with the kit. But here you go if you want a head start.
http://www.nitrousexpress.com/instructions.html
