Project: Doing it myself
#384
Received 1,194 Likes
St. Jude Donor '15
I'm pretty sure they said not to, actually.. lol
#387
St. Jude Donor '15
No pictures of installing it? Everyone loves fuel system pictures.
#388
#389
Now you pray that it works. Almost no one gets it on first try.
#390
I ended up making my own coil relocation kit. The only thing I had to buy is the firecore50 wires. I'll have $145 total invested.
Driver side inner fender
Passenger inner fender
#392
#393
Picked up some more much needed parts. I picked up the professional model Hp tuner so i can data log. A Mighty Mouse catch can. And a vacuum block.
Since the corvette has absolutely no room in the engine bay. I had to make room. So i made a bracket for the fuel pressure regulator and the catch can.
Regulator:
Catch can:
I also finished installing the fuel system and hiding the wires under the intake.
Regulator:
Catch can:
#396
that intake and valve cover setup look awesome. sure last thing you want to do is throw more money at it but with huge fuel system and possibility of belt slip the Billetech alternators are good peace of mind.
will be interesting to see dyno numbers. I've always wondered what the practical upper limitations of the normal ECS intercoolers are too, which I bet you'll be pushing here
#399
That's how ECS installs their kit. Worked fine before. Only one way to find out if it'll be an issue.
