Don't wanna spend +$1k on a vented hood? Look no further!
#242
I did see good drops especially when in motion..
#243
A-A-Ron, can I get a pic of the bottom of the close out panel? I am trying to decide if I won't to get that route and mod the panel to get the clearance needed.
#244
Premium Supporting Vendor
Thank you for all of the orders. I certainly appreciate it. Looking good guys.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
#249
Any thoughts on if these vents effect the aerodynamics of these cars for better or worse? Gm spent alot of time designing the aerodynamics of this car......
#250
#252
a lot of the standing mile guys have found this reduces lift on the nose and the world challenge hoods, designed with countless trips at the track, basically do the same thing. well established that venting the hoods on the c6 make a big difference at speed.
#257
Thanks. ...makes sense
#258
yeah, i think with 99% of drivers it's just for heat issues. i'll see how the aero impact is though, i will be doing a 1/2 mile event probably at 170mph i'm guessing in october and plan to do some hood vent setup like this sometime after, so will be interesting to see if notice any difference at whatever the next event i'm at is
#260
Sorry, but pitched it lol..cut too much off to slim it down. Even with the higher cowl, I wasn't able to place it where I wanted to, so I didn't cut the new hood. Good thing too, because I had to return the hood. Gel coat started to bubble and I had some signs the fiberglass was cracking underneath. Only had it on the car for 5 days. Was already getting into hundreds of dollars just to repair it before it could be prepped and primed. Wish I could help. Looks like I'll be getting a ACS Composite L88 hood.
