Don't wanna spend +$1k on a vented hood? Look no further!
Turned out nice.
It will probably cause my engine bay to get dirty really quick. Water..... hmmm I drive with Hoosier DR so i will not drive the car if its gonna rain lol.
I'll give an update as soon we hit our 100 plus summers here. But what I did notice quickly is that after driving the car hard and getting the temps to around 210 it will quickly drop down about 10 degrees. Before it will take along time to drop. Sometimes it wouldnt drop at all. So far its working. You also see the heat waves coming out the vent.. So its doing its purpose.
I removed the hood liner since it was damage before from a shredded belt but you can cut the hood liner but you will be cutting the Flag logo. I got some 1/8x3/4 aluminum sheet and folded some Z shape brackets and bolted it up using the stock vent bolts. I doesnt look as clean I wanted it to but I might redo it again once I can think of a cleaner idea. I post a pix of the inside in the my post
http://www.jegs.com/i/SLP/847/620032...jyfhoCDqzw_wcB
Here's a link I found and it comes with the underside. I got mines from a member on another forum so it was just the vent nothing esle. Only $200 also
http://trackspe.nextmp.net/shop-by-p...-t1-kit-3.html
Found this too, gonna ask if they can make some that open/close for water concerning anyone getting into bay. Just saw yours come with drip tray
Ill prob go with this one but just use the one center vent up high about where ZR1 vent is... Gonna order tmrw.. Looks pretty sick too.
#33
Will do bud thanks for posting got me thinkin/wantin to do this now..
#35
#38
https://www.corvetteforum.com/forums...r-louvers.html
Found a few other threads on track spec just wanted to share.
