boosted Ls2's. ....lbs boost/hp?
#41
Huh! That seems low to me. I'm not sure, but I was under the impression that an SD tune would still use the IAT sensor? It would be a waste in my opinion since the ECM is not seeing the low temps. Ask him about the afr and timing.
#42
Received 1,193 Likes
St. Jude Donor '15
Tons of people are doing it and this is the first time I've even heard of someone saying corrosion is a problem
It sounds like he doesn't know what he's talking about and/or isn't familiar to this methodology so he's giving excuses
Spraying meth on the IAT sensor and pulling a ton of timing if the temp doesn't go down is one of the better things that you can get out of meth, so I would def. want it done that way.
At worst.. let's say it does corrode the IAT. They're like $12, who cares
#43
Yes, SD tune still uses the IAT
#44
#45
Man, I know your not happy, I would want some answers with these results, something's not right. even if you were making another 2lbs of boost with a smaller pulley it would not be in lone with what you should be making, your car should have right around what mine is making, I would have thought around 650 (with 3.8)
what your plans ?
what was your car making prior to the install, Do you know ?
what your plans ?
#46
St. Jude Donor '15
I also would think that it would take a LOT of meth to really do anything to it, if it would even do anything at all
#47
In the past a lot of people talked about corrosion, but that was due to the incorrect materials being used in the systems and most used water too. I highly doubt that that meth alone would corrode the IAT sensor, and if it does it's because is being mixed with water in my opinion.
Honestly I'm with you and I think he's unfamiliar with it and doesn't know how to take advantage of the meth capabilities.
#48
Was planning to as i did an iat relocation kit w/ ls3 maf (2005 car) and he said where the meth was spraying it would corrode iat sensor. ...so we did speed density tune and sprayed meth on top for safety....? So basically the car is not recofnizing any of the benefits from the meth.....How much power would be lost in a 85* humid dyno atmosphere?
No offense to your tuner, but I would find someone with a little more experience tuning methanol, I would be pretty pissed with those results as well. Make sure you are not missing something obvious as well such as boost leak, slipping clutch, or blocked catalytic convertors.
I went through this last year, put my Meth on and car wouldn't make more than 450! Stock clutch slipping under boost and I never knew it, very hard to tell unless you know what to look for. Pulled that clutch out and it looked brand new, just couldn't produce enough grip. Threw on a Mantic and back in business.
#49
Probably a big part of the problem, you have to spray over your IAT or you are leaving half the meth benefit on the table. Car was probably yanking all the timing as the temps climbed especially if you didn't do a cool down pull. The real story is how much timing was he running and what were the IATs. This goes along with what I said about guys making big numbers F/I under ideal temps in the fall/winter/spring but your ECU crushes you when temps start to get high.
#50
Great points. I am not running cats, it is 1 3/4 - 1 7/8 stepped headers to full 3" Z06 npp system. I do still gave stock clutch with only 26k miles on it and zero racing, but could be a factor. It was a really humid night when he had it on the dyno....soi know that hurts boosted setups. ...? he us supposed to do some street tuning with it today...so we will see. He said we could put it back on the dyno when i come to get it to show me a pull....but i'm certainly no expert and not sure i could recognize a problem......
#51
St. Jude Donor '15
OP: Monster LT1-SC or Mantic twin are your best clutch options, IMO
#52
Yeah, i will be going with mantic soon it looks like
#53
The humidity the night it was dynoed was 88% and 80+degrees....tuner said that he thinks that could be why it only made 8lbs of boost.......that seem logical?
#54
I've heard that heat and humidity may cause a drop in boost. Now, since you are running meth I highly doubt that your power is due to the temperatures and humidity being relatively high. That's what meth is for, to overcome the temperature variations and keep it constant along with the octane gain and the possibility of adding a higher ignition timing.
#56
#57
St. Jude Donor '15
Yes. Computer has no idea what the temps are after whatever it's reading in the MAF (assuming that's the sensor that is connected, like you mentioned it is).
#58
But the meth is still adding a good bit of protection for my motor even though not being utilized for power.....right?
#59
