The Best Performance Engine & Trans Mounts on the Market @ Hinson Motorsports
Former Vendor
Urethane Engine & Transmission Mounts for the Corvette C5/C6
MADE IN THE USA!!!
These urethane engine mounts are designed for a great balance between engine control and vibrations. They have been tuned for both street and track applications. Replace your stock rubber mounts for improved throttle response and reduced engine movement.
Features
* Designed for street and race cars
* Direct replacement for stock rubber mount
* Uses factory metric nuts (not included)
* Stainless Steel construction for rust free operation
* Interlocking design for fail safe operation
* Uses factory heat shield (factory heat shield is required)
* Fast installation
Applications
* 1997-2013 Corvette C5/C6/Z06
Urethane Engine Mounts Standard Height C5/C6 Click for Pricing
OEM Standard Height
Urethane Engine Mounts (Shorter Version) C5/C6 Click for Pricing
.360" Shorter
Also Available in Engine & Transmission Combo Packs
Urethane Engine & Transmission Mount C5 Combo Pack Click for Pricing
Urethane Engine & Transmission Mount C6 Combo Pack Click for Pricing
*Want to become a dealer for these items??? Email chris@hinsonmotorsports.com
As you can see in the below cut away image, the engine rides on the durable urethane. This is how we control engine movement while not passing every vibration in to the passenger compartment. The inside of the mount is interlocked. Even if you found a way to damage the mount, the stainless interlocking design will keep it all together. The design is built with stainless steel, so they will not rust. They accept your factory nuts. This means there will be no emergency hardware store trips.
MADE IN THE USA!!!
Features
* Fast installation
Applications
OEM Standard Height
.360" Shorter
Why Are They So Much Better?
Former Vendor
These are great mounts that will perform for years to come and not need any maintenance or replacements.
Former Vendor
Sold in combo packs to help you save money......... Specify which height mounts in the order notes.
C6
http://www.hinsonsupercars.com/p-135...-corvette.aspx
C5
C6
C5
EX1 (02-03-2016)
Former Vendor
Former Vendor
NEW PRODUCT ALERT
HINSON Motorsports now has heat shields available for our C5 & C6 performance urethane engine mounts. The heat shields are designed from the best materials in the business. The heat shields work with both engine mount heights that we offer, and are designed to prolong the life of the mounts that will be exposed to extreme heat caused by racing conditions. Already have our mounts installed? No problem. These heat shields will install easily, no matter if your mounts are already in the car, or your just now getting ready to install them. It's as simple as wrapping the shield around the mount. Click the links below for pricing and availability.
*THESE WILL WORK WITH YOUR EXISTING HINSON ENGINE MOUNTS
Click Here for Price & Purchasing
