Matt@FSP+416ci+YSI+Alky+FSP Cam+Superglide+Stage 1 Fuel=?
#1041
Received 1,193 Likes
St. Jude Donor '15
Yeah I wouldn't think that's it if you have a brand new one. Gotta be something simple.. hopefully 6 rib fixes it
#1042
Yea another way to kill that idea is run a belt from crank to flip (timing belt like unreal suggested) and not ac go WOT see if it breaks..
#1043
I'm curious, have you had the ac actually turned off during the wot runs that broke the belt. If it's off, I wouldn't think the clutch would have an opportunity to lock up, but that doesn't mean the pulley bearing on the compressor isn't going bad. I have had brand new ones that were bad before. Just something you might look at. Also, since you are waiting on parts, you might try putting the ALT/PS belt on and setting the tension to see how hard it is to turn by hand without the 4 rib AC belt on the jackshaft pulley. That might give you an idea of the stress placed on the AC belt trying to turn the accessories in case there is an issue there while under tension. I think the pulley you say isn't doing anything is designed to give a slightly better belt wrap of the 4 rib AC belt on the jackshaft pulley. Just my thinking, but if you have enough force to break a 4 rib, even if it doesn't break the 6 rib, it may not take long to damage it. I can definitely see it helping with belt slip over the 4 rib though.
#1044
I know what he was talkin about i was throwing that out there only as troubleshoot.. Dont wanna cog tho. I understand it is supposed to help wrap i think id be better with c5 bracket for wrap
#1045
All good recommendations to check tho..
#1046
Maybe I'm missing something. The c5 bracket you are talking about is the ac bracket correct? If that's right, that will increase wrap on the crank and the ac but won't do anything to help the wrap on the jackshaft pulley.
#1048
6 ribz, to be cont...
#1050
Almost there..
#1051
St. Jude Donor '15
What's left?
#1052
Rack back in n done, hopefully
#1053
Ok got it back all done and its 100% now. Thanks to Rodney and Matt of course, it wasnt easy. Didnt get on it really because who can blame me but so far so good. I must say this turn-one power steering pump makes driving this car a whole new experience!
#1054
Turn-one NASCAR feel pump..
Turn one pulley
6 rib fleet still in tact, after some harsh shifts lookin good.. Gonna keep an eye on it.
#1055
Best way to describe this pump is look at this video and how effortless it is for Jeff Gordon to move his wheel. Its exactly the same..
#1056
St. Jude Donor '15
Hopefully that solves the issues for you!
If I had known about this brand I would have gotten one too since I paid close to what they charge for a brand new GM one anyways
#1057
I hope so too.. I think this is the ticket though with confidence.
On your next one please get this one its insane a whole new experience of driving!
#1058
St. Jude Donor '15
Hopefully this was the last one for me! Speaking of which.. I need to change the filter I put on the power steering return line
#1059
St. Jude Donor '15
lol, you buyin?
