07 base model with A&A supercharger
My 07 base model is currently in the shop getting an A&A supercharger installed. What should I expect to feel power wise? Will it throw me back in my seat? Will I feel the power at lower speeds or wil it kick in later. Can I expect to get from 0-60 significantly faster?
Your run flats won't be able to hold the road it will put you back into your seat. Your going to have to learn to drive your car with this power all over again. Have fun.
1. You will have difficulty hooking up the tires at WOT in 1st and 2nd gear. So you need to learn how to manage the throttle to stay out of trouble. I need wider and stickier tires.
2. Your clutch might start to slip. Mantic dual disc resolved that.
3. If your harmonic balancer has a slight wobble, I recommend you replace the HB with an ATI HB (pin the crank) while everything is out. That will save you $$$ and it will eliminate the chance of belt chirp. I learned the hard way.
4. Yes, low end will also have more hp and torque.
5. The smile on your face will be bigger, especially around 4500 rpm!
0-60 will probably not be much faster due to potential wheel spin (unless using drag radials). You will definitely feel more power everywhere. ...especially above 3500rpms
