How may saw an improvement with Dewitt's 2" shorter radiator?
Received 1,194 Likes
St. Jude Donor '15
Much obliged, I don't have that blocking issue with A&A the whole intercooler sees air the way it is I should post pics.
St. Jude Donor '15
Hehe, except with mine when I assembled it all I took care cutting the stock shrouding on the bottom so it covers the full intercooler and you don't see around it so it forces the air to go straight through the intercooler. My IAT's are extremely low but I think because the fins are slightly facing down as the intercooler sits on an angle, this pushes the air down after it leaves the intercooler and turbulates with the air trying to come in behind it via airdam. Either way my coolant temps aren't too bad so I'll leave it as is.
Doesn't matter A&A or ECS, it isn't for more intercooler flow, but more flow to the radiator. It really opens up the front end and allows a lot more air up front.
Driving home today from work. Only 104F out. AC ice cold and tunes blasting.
WOW! That's awesome yeah maybe one day I'll open mine up when I get a new Z06 front end
Nope, just took a saw and went to town.
St. Jude Donor '15
What's the lowest temps you can have the fan come on in a 06 Z? They set mine at 194 speed 198 high speed I think..
Car runs between 189 and 198. Highest temp I seen was 210 in stop and go. Cools right down as soon as I can get her up to 35MPH for 1/2 mile. 85-90 deg day.
St. Jude Donor '15
Lowest cell in the stock OS is around 190. Custom OS's change it to more like 163
#34
I was just about to buy a Dewitt's for my ecs 2200r kit . Haven't ran the stock setup yet ,but was planning on a 160 Tstat . Motor is a lower compression 6.0 iron block in 09 vette . From the sounds of it , seems like a waste ?
#36
Former Vendor
Many people install the radiator and say I saw no change or expected it to go to 160 or something. As stated by someone above, you can't run lower than the thermostat and the factory fans are not design to start until about 230. If you want it to run cooler, then you have to tell it to run cooler by installing a 160 stat and starting the fans at a lower setting. While this thread is not very complimentry, there are several others where people have reported a major difference. These are usually guys that live in very hot climates or push the cars hard. You are only going to see the extra when you have a demand for the extra.
#37
I have the 2" cut down and the dual spall fans. I saw a pretty big difference but it wasnt until I changed to distilled water and red line water wetter. When I did that I was able to see the difference between the dewitts over the stock radiator. Worth the money in my opinion.
#38
#39
Dewitts radiators are 100% worth it. The thing that may not be worth it is the dual fan kit. I think the stock fan cools just as well, but stock fan isn't an option with cut down.
I should just call Dewitts and see about the 17" fan for cut down.
#40
Nick, it would be easy enough for you to modify the shroud they made me work with your cut down rad. I'm sure they can find a way to mate the brushless fan to the cut down. I didn't look into it because I'm fine running the ecs dongle
