F1X belt woes
F1X belt woes
I have a 06 Z with fully built engine with an F1X blower and RPM transmissions auto conversion running on E85. Im running the Taylor performance direct drive and a 10 rib dedicated blower belt. I have an 8 inch IW damper and a 5.25 inch blower pulley for now. Imrunning the green HD gates belt and I have tried everything from loose to tight on the tension. The head bracket and the tensioner are stock procharger and the J bracket is Taylor performance as well. It is blowing thru 3.5 tubing to an air to air IC and 3.5 tubes to the TB. I have a 60mm blow off installed. It is making 15,7 psi with this pulley configuration.... EVERYTIME I run it through the gears it tosses the belt. I have checked pulley alignment and that is good. So far in the 4 times it has tossed it ,it has popped a hole in the hood,ripped out the right front wheel speed sensors wires twice and finally the last time it tossed the belt remnants in my acc belts and pulleys.
Im not sure where to go from here. As bad as it is to eat 35 dollar belts, it is tearing up other things along the way.
Has anyone here experienced this situation and what was the cure?
I have same setup holding my F1X on. I'll bet $ that the water pump has worked it's way out some, take a look. We had to weld the pump pulley to the shaft as I was having the same issues. Now I run a 3.8 upper and 8 lower to 7400rpm with 32psi and zero issues outside of bending the procharger tensioner rod every now and then haha. Good luck.
Are you sure the belt isn't rubbing the thermostat housing area of the water pump, or the face of the water pump casting?
What size belt are you using for that pulley combo?
What happens when it gets 'tossed'? Like snaps immediately, or throws a rib off the front or back of the blower pulley till it cuts a rib off and the rest of the belt fails?
I had belt problems with the same bracket. Switched to an A&A with their direct drive setup and never had a single issue. I run this setup on 3 cars and had belts on for 6-7 months and still to this day never had an issue. They are still running the original belt.
great talkng to you tonight Fran. I will be calling A&A tomorrow
Received 1,261 Likes
I also have an a&a 10 rib procharger bracket with the hd tensioner and secondary drive and I haven't had any problems at all, I have had nothing but success with a&a's products... granted I'm only running a measly d1 though... on a side note your car looks like a beast man, I dig it
I ran an F1a and F1a-94 on the procharger/dallas performance 10-rib wiith an 8"/3.85" pulley combo with no belt issues.
I installed the F1X and a 4.125" and then 4.5" blower pulley and I've had some trial and error trying to find the correct belt size. Too tight of a belt meant I had to loosen the head unit to get the belt on and the belt would touch down on the water pump thermostat housing/outlet when under load. Too loose and it seemed to throw the belt backwards and hang 1 rib off the back of the pulley towards the motor till it got cut off and turned into a 9 rib.
I'm also running a tial 50mm bov w/ the recirc fitting and a filter pre-intercooler and a stiff spring tial 50mm non-recirc on my intercooler tank, so I think I need to vent better close to the blower.
I also had to shim the blower pulley to line it up with my crank pulley (different than my F1a's), and I'm not sure my tensioner idler pulley is lined up right, so the shoulders of this tensioner pulley could be pushing the belt off.
Basically it worked awesome on the f1a/f1a-94 and I've got a few kinks to work out on the f1x, but it's not chucking belts every pass either, seems to only push the belt off when I touch off the rev limited spinning the tires, which leads me to think it's surge like playtoy mentioned. I'll add a 2nd blowoff valve pre-intercooler before I change any of my brackets, the procharger setup is super easy to swap belts. I think you have to pull the head unit with the A&A
Platinum Supporting Vendor
I sell my A&A SC bracket designed to fit a Procharger headunit from P1 to F2 and 6,8, & 10-rib option. It works really well and even though it takes a little more work to replace the belt, you really won't have to replace it for a few years anyway.
If I were you I would be running at least Two of those BOV's with 2-3# springs directly after the blower discharge, pre intercooler. The closer to the blower, the better.
If belts are aligned correctly and you don't have any surge issues, belts last a very long time. Im going on 3 years and over 15000 miles on a 10 rib belt with A&A Bracketry (YSI) and the belt still looks great.
I myself have had issues with procharger brackets in the past and I am not a fan, a lot of other people I know aside from the ones posting here have made that swap from the PC bracket to either the one that was offered by ECS or the one that A&A offers.
Over the years I have tried brackets from all the major players in the game, A&A by far has the best engineered product for the corvette in my opinion. Granted the belts are a pain in the butt to change, but if its set up right, you wont be changing belts!
Friend had the same issue. Swapped tons of stuff, bent a ton of PC rods, had nothing but issues with PC brackets. Finally went to an A&A setup and zero issues, and no slip since then.
It seems obvious A&A is doing something right with their brackets. Running 19-20 lbs on my new build with a YSI, 8 rib, and flip drive. I have about 600 miles on it now with absolutely no belt issues and no slip.
