C6 Z06 highway coolant temps
Hello everyone,
As the title says, I have a C6 Z06 with an A&A V3 supercharger. As happens fairly often with these, my fan connector melted and my fan stopped working a few days ago.
The garage I work on stuff is about an hour away from my house and to ensure I wouldn't have any issues with the fried connector I pulled the fuse and set out today. There are some lights around my house but most of the drive is wide open 4-lane highway so with temps around 80 I wasn't worried about the car getting warm. Anyways, it seemed I caught every light on my way out and the car got to around 200 before I got to where the road opened up. I was able to drive for about 30 mins and even with the heat on and 60-65 mph speeds the car never cooled down below 200 for more than a few mins, which is not normal for my car. On this same trip (with similar weather temps) a few weeks ago the car ran mid 180s.
I was very surprised by the higher temps as it seems my fan must be running a lot more than I expected, including when I'm running down the highway at speeds above 50 mph.
I wondered if this was the normal or if I'm having some sort of issue with the car? I know that the intercooler blocks a good bit of airflow to the radiator but what have you guys seen?
Thanks in advance
Thanks in advance
200 is nothing. Fans on stock cars don't even kick on high until 225 or so. C7s run 220ish normally. Even 200 on your car is below where it runs from the factory. Don't worry about it. If you start seeing 240+ then you have an issue.
Agreed, bone stock my car was 220 dunno why people freak out over that lol. Id be freaked out at 240-250
I wasn't really concerned with the temps, but I guess I was surprised that my fan must be running when I'm at speeds above 45 mph to keep the car cooler than it would be without. I didn't realize that it was running once I was going down the road until I had pulled the fuse because of my melted connector. I always figured that above 40 or so air moving through the radiator would be all of the cooling it would need.
I figure it's perfectly fine and I'm overthinking the whole thing.
Thanks again.
Thanks for the reply, Unreal.
Thanks again.
Thanks again.
Received 1,193 Likes
St. Jude Donor '15
I don't even turn my fans on until high 190's and they don't get to pretty high until 210'ish. Plenty of cars run over 210 all the time.
I might have to look into having that changed for the same reasons. I'm sure my fans are coming on earlier than stock and from what I saw on my drive yesterday it appears they are running a good bit even cruising down the highway. I'd rather not have a fan (or something else) burn up from running too much.
