ECS tensioner bolt broken
#41
Received 1,194 Likes
St. Jude Donor '15
On mine the idler was still there, just basically tilted sideways towards the head unit. I didn't see it until after the belt was snapped, so I have no idea what it looked like before that.
#42
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
Interesting, I'm going to sit down with the crew here and make some decisions, odd that this is just now becoming an issue, but regardless we'll look into this.
#43
for whatever it's worth the tensioner on my procharger A&A backet was also bent recently for no good reason too, it's the old style bracket and i know they have since upgraded the tensioner setup on all new brackets but just making the point that this is not an ECS specific issue as all the blower kit providers have had past issues with tensioners.
#44
#45
ARP L19 tensioner bolt
#46
St. Jude Donor '15
My belief is the portion of the bolt that threads into the idler is coming loose when people are tightening the nut that holds the manual tensioner still. This creates a small gap between the idler and the bracket. This makes it possible for the tension on the idler to bend the bolt, causing it to eventually break. If it's tight, it can't bend, and the only way it's breaking is if there is enough force to basically shear the bolt in half.
Given that this portion of the belt is on the "loose" section of belt, I don't see it having enough force to shear the bolt
I would have to take a better look at it to be sure I'm remembering how it works properly, but that is my best guess going from what I remember when I replaced mine.
#47
I replaced mine with a cheap'o bolt from Lowes and I haven't had any problems since. I don't remember the grade #'s, but the replacement was a lower grade bolt than the one that came with the kit (because that's all Lowe's had in a full threaded version)
#48
I used a B7 bolt - the local bolt supply warehouse did not have any "all threaded" grade 8 in 3/8" 16 3.5" - B7 is 97K versus the Grade 8 being 130K. I used a regular nut and lock washer as opposed to the nyloc along with thread lock where the bolt screws thru the bracket as Xtreme did. The car now makes a solid 12 psi and the belt alignment has held steady.
#49
didnt realize the bolt was broken until I saw the belt was off a rib.
#50
St. Jude Donor '15
That is exactly what I've been trying to bring to everyone's attention. I don't think the bolts are bad. It doesn't have to be very loose to put a lot of extra stress on it and unless it's really tight, that nyloc nut has just enough grip to back the bolt out slightly before the nut gets tight. Some loctite on the bolt where it threads into the bracket and replacing the nyloc nut with a regular nut and lock washer fixed the issue for me so far.
This is looking like a pretty common issue. Will be interesting to see what changes are or aren't made to help.
#51
What we have decided on, which is exactly what you guys have concluded as well it appears, is that the bolt must be backing out a bit. It's the only thing that makes sense.
We are going to assemble them with a really hard lock tight and if anything in the assembly every needs replacing like an idler, we will just send the entire assembly.
Thanks for your input guys, we appreciate it.
#52
St. Jude Donor '15
Good to see you are improving the system.
Any particular kind of loctite? I was going to just put regular red loctite on mine next time I have it off (which is hopefully no time soon!)
#53
Thanks Doug. I think the loctite will probably do the job. Switching from the nyloc nut to a regular nut with a lock washer also seems to help.
I used loctite 272 which is for bolts over 1" but the normal 271 should be plenty. You just have to let it set up a little.
#55
St. Jude Donor '15
Wonder why it happened to so many of us all at once? If I ever have that off I may try to find a stronger bolt to use in the future. I'm not sure what's above grade 8 though?
#56
Welp - add me to the list as mine just snapped. Luckily I was at home when it happened.
As habit when I park the car at home, I pop the hood to let the heat out. I had been on the freeway giving it "the business" following the changing of the plugs (took out TR6 and put in some BR7EF gap .28 - wow, cured all my high rpm stutter/misfire issues) and noticed the belt was off 1 rib. Curious as I hadn't seen that issue once I got the alignment correct a few weeks back. Get the belt loose, back on the pulley correctly and as I go to tighten it back up - the tensioner bolt halved itself
Pretty much the same area that everyone else experiences.
Not falling on deaf ears. As schpenexel stated, I noticed that about mine as well. I actually took a shaved down open end to wedge down in there to to tighten bolt (as much as I could).
#58
St. Jude Donor '15
My bolt is missing the spacer... Wounder if that's a big deal, I have to change mine out cuz the bolt got stripped I always used the size wrenched that was in instructions / belt video but I always seemed a little too large and that bottom bolt the head got stripped and I need to change, the top bolt seems to fit the wrench better tho! What size wrench are you guys using?
#59
