ECS tensioner bolt broken
#61
IT happened to me as well. Replaced the belt, the bolt, and the idler pulley. Also used loctite for a peace of mind. So far so good. But only time will tell.
#62
Thats a lot of broken bolts lol..
#63
Received 1,194 Likes
St. Jude Donor '15
I started a trend
#64
St. Jude Donor '15
Picture of mine.. because, why not?
#65
St. Jude Donor '15
My bolt is missing the spacer... Wounder if that's a big deal, I have to change mine out cuz the bolt got stripped I always used the size wrenched that was in instructions / belt video but I always seemed a little too large and that bottom bolt the head got stripped and I need to change, the top bolt seems to fit the wrench better tho! What size wrench are you guys using?
#66
#67
St. Jude Donor '15
Anymore broken bolts??
#68
Pix of new stout bolts too?
#69
My B7 - bought in 4" and cut off 3/8" or so. Used with a flat washer under the bolt head along with a flat washer, lock washer and a regular B7 nut on the other end. Used Red Loc-Tite on the threaded section that passes through the SC bracket.
So far, so good and I'm fairly confident that it will hold up just fine for the long haul.
#70
Wow thats a nice lookin bolt, doubt that will be breakin anytime soon lol...
#71
bolt
I had mine break last night on the way home from a cruise in. Called Chris at ECS this morning for a replacement bolt and idler and ask for it to ship today because Monday is a holiday and I am trying to get ready for the Holley LS Fest next weekend.
#72
St. Jude Donor '15
I'm tempted to tighten/loctite mine this weekend just to be sure it isn't going anywhere.
#74
Me too. I wish ECS would provide us some clarification if we should do this or leave the installed bolts alone.
#75
I would def loctite that B..
#76
seems like all of this is just from the bolt coming loose, if were me I'd think you could just slide some open ends in there, loosen the bolt a bit and drop loctite down on it, tighten it all up and let sit over night and forget about all of this and call it done?
#77
St. Jude Donor '15
Not enough room with it installed. You can grind down a wrench and barely squeeze it in there enough to tighten it, but there's not enough room to unscrew/loctite it without removing the head unit or at least taking the bolts out so you can move it around. I may do that on mine this weekend just to be sure they aren't going anywhere
#78
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
I also checked into if we changed hardware manufacturers and we have not. Same we have been using for years.
So all we can conclude is that we will lock tight the hardware here and replace the nut with a std nut and lock washer instead of the nylon lock washer.
#79
Like I said earlier, we have not seen this issue here, but as they say "an ounce of prevention..". So to take a few minutes and check to make sure that bolt is tight certainly can't hurt.
#80
Add mine to the list. 2008 A6, ECS kit installed in June. Heard a rattle & the tensioner bolt had broken. Would a grade 10 bolt work in place of the grade 8?
