ECS tensioner bolt broken
#101
Received 1,194 Likes
St. Jude Donor '15
Mine broke first dammit! lol. I think anyways
Do I get a shirt too??
#103
i think it would be agood idea to put a washer between the bolt head and the bearing. then you can go in there with an openended wrench and hold the head while tightening the nut.
#104
St. Jude Donor '15
Is there enough room to space it out any you think? I noticed there is very little space between the idler and bracket on the side where the head of the nut is
#105
No way to fit a wrench in there to do that.
#106
St. Jude Donor '15
Maybe a shaved down wrench?
Or just red loctite the thing and not worry about it
Can't hurt to switch to a lock washer and regular nut too if you have it apart already
#107
St. Jude Donor '15
We ain't all rich, buying snap-on tools, geez.
My thin wrench is a harbor freight special meets a grinder, lol
(jk)
(jk)
#111
St. Jude Donor '15
I actually do have some snap on tools.. mainly ratchets, which are my favorite by far. I sold all my snap on impacts and went Milwaukee though. They make snap on look bad on that product line
If I did it for a living I'd have a whole lot more, just not justifiable for the regular DIY guys
#112
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
Snap On is not what it used to be on many things now, just the way it is. I like the Milwaukee stuff too, especially the battery powered stuff, impact guns etc.
#113
the regular wrench on the left wont grab the bolt properly. the wrench on the right will, its a little offset, which is not clear on the picture.
regular wrench in there:
there is 8 mm between bolt and blower. if you space out the bolt by 2-4 mm, you can hold it with a regular wrench.
#114
Not with a 10 rib.
#115
St. Jude Donor '15
First world problems.
#116
Hows the weather?
#117
St. Jude Donor '15
57 degrees and sunny!
Was around freezing this morning though
#118
Looks like its time to order some snap on thin wrenches just for this job.
Romandian, what kind of wrench is that on the right?
In my case I really don't need to grab the bolt, since I will just be taking the locknut off and swapping it out with a regular nut and lock washer, when I swap my belt.
#119
no idea, i just have it, ratcheting wrench, chinese probably.
if the space is narrower, maybe a straight closed wrench will fit in there? yeah, you might grind that one on one side. but i tried to get a straight one and would have had to specially order it.
#120
Received 1,261 Likes
