RPS triple or what other option is there for 1000+RWHP ?
Supremacy 1 car at a time
I had no luck with the RPS so I go for Mantic now and there spec E-trim can hold it too, if you're going to a shortcut directly the end of this chapter with Tilton
OP, if you have anyone near you with a mantic triple, definitely try to get behind their wheel. If you want to go to ECS, I'm happy to let you take a short spin. The mantic triple is by far the best clutch for high torque/hp builds. Good luck!
So it seem like there are few recommending Mantic 9000 triple I assume.
Mantic 9000 triple $2450
RPS triple $2800
Centerforce DYAD $1715
Witch of those are the best for street and strip?
RPS triple $2800
Thanks. No one have Mantic in me country. I might just jump on a air plane and so I can take you car for spin
I drove a few RPS triples and my biggest complaint is consistency. Everyone I tried felt different and most chattered real bad, but a few were smooth?? But I refused to pay that kind of money and not know what I'm going to get. I took the spec twin out of my car cause it chattered so bad. The closest clutch to the DYAD I can think of how it drives it the RXT you just had but the Centerforce is a little lighter on the petal and a tad smoother. The RXT is probably a lot closer feel to the DYAD DFX really. Its up to you but I'm telling you its hard to beat them for the performance and the cost. Never driven a Mantic so I can't tell you about them other than they look nice in the pictures. I've driven a ton of cars with a million different clutches so I'm not just an individual who had a single clutch installed I do run a shop from my house since 1995, its small and mostly by word of mouth.GL! Hope all the info just didn't confuse you on what your going to get lol !
yes sir it was triple and I didn't said I didn't like it but I said I don't have a luck with this clutch lose 3 of them 2 was on supercharge cars and one was on nitrous C5Z
supercharge was perfect until we spray an extra 150 shoot it's start losing, and the other supercharged car lose it at the first dyno, for the nitroused C5Z it was working well on dual stages on dyno and at the event clutch died as soon as the driver hit the 2nd stage.
FYI: all the cars I mentioned was between 1450-1600 WHP.
I´m no clutch expert but I did once have twin medal speck and it was way too aggressive which is not the best to get constant 60” time and on top of that it could not handle the heat from few runs with short cool down time. The clutch did start to slowly break apart coursing it to hang in all the time. What I have now is RPS twin light which is smooth on 60” witch make is easy to reach 1,4x-1, 5x time. And I never had any issue with heat even with few run´s in role. It just gave in after I turned up the boost from 9 psi to 16 psi. I just want to get new clutch with can handle the power I have and it needs to be smooth for takeoff and it must handle few runs with short cool down time.
It just seems that most of the 1000++RWHP cars are using the triple RPS with no issue. ( I´m not looking to spend 3k for clutch if I can get something ales witch can do the job)
p.s. I did run 1/8 mile at 6,12 at 120MPH witch sould be in 9,3xx at 150mph+ at the 1/4 . This was as I drive it on the street with pump gas.
Jeff, I'd like to stop by the shop and check out the car with your clutch. Maybe just around the block after we get out of the sticks to see what a quick release feels like just to 20-30mph in the car even riding shotgun. Before I tear in to mine, I'd like some first hand experience. I've been through and raced a lot of clutches too, not as many as you, but it's hard to squeeze the trigger at 900-1000rwhp when your go to clutch and the customer support isn't there. It will probably be 3 weeks from this weekend, since I'm in prime fishing season.
#33
The RPS is hands down the most impressive clutch I've driven. The lightweight disks make it shift lightening quick, and the carbon on carbon surfaces are the most forgiving to slippage/heat. Nothing is going to warp. My only complaints are the heavy pedal and the price...but carbon/carbon is very expensive and time intensive to produce. The ones I've driven have had ZERO chatter. My buddy removed his RXT due to chatter, and installed an RPS triple. I have never seen it chatter once. He did take the time to break it in correctly, to make sure all the friction surfaces were fully seated, before slipping it hard. This is essential for long clutch life.
The pedal travel is very short, and you should run a pedal stop because of it. It does take some time to get used to. A smaller bore master cylinder would be perfect, as it would lengthen the travel a bit and lessen the effort...but nobody makes one.
I will say that I've never driven a Mantic twin/triple. I would like to test drive one, but I don't like ceramic friction material. Every brand I've ever driven with ceramic has chattered on take off. I may be interested in their organic disk twin, as I'm in the market for a street clutch for my NA Z. A $2500 RPS twin is a waste for a purely street car, IMO.
#34
What to do!!
I would have thought I would get more response from people that have been using RPS on the dragstrip! Maybe not to may doing that out there taking their cars to the strip.
Doug@ECS and many more recommend Mantic 9000 but what about real would data from the strip!! It is not the same to do some roll on the street as going to the strip were you have extreme grip which will stress your clutch. I cannot go with Mantic without some reference other than street drive. I do not care if the clutch is stiffer than stock ( not to many stock parts left in the car anyhow)
I do not want to spend mor than I need but I only want to do this once.
#35
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
What to do!!
The slip off the line is great and the separation at WOT is great.
#36
Former Vendor
However, what kind of power are you going to be making? How is the car going to be driven? Also feel free to give us a call if you want to go over details. (817-750-2000).
#37
Most of me driving Street with some drag racing and track as well. Power is in the 900- 1000rwhp rang I think. Car is 3650 lb 402 with twin APS/DKT 6266.
#38
Wouldn't touch a CF with a 10ft pole. Do some more searching on failed DYADs.
#40
OP GL! I'm sure you'll find something to work for you there's a lot out there currently.
