747rwhp procharged zo6
I just retuned my 07 zo6 for e85. picked up a ton of hp and tq. Mods are stock bottom end ls7, blower cam, valves redone, D1 procharger a@a kit, arh, billy boat exhaust, msd fuel boost a pump, dsteck flex fuel kit, injector dynamics 1300.
On 7lbs and 91 oct made 612, with e85 i made 747rwhp and 654ft. Car runs like a dream and smells of cheap vodka! love it
I just retuned my 07 zo6 for e85. picked up a ton of hp and tq. Mods are stock bottom end ls7, blower cam, valves redone, D1 procharger a@a kit, arh, billy boat exhaust.
I already have headers. ARH. Honestly the car had a good 40whp left but didn't want to push it. Timing is still very conservative. I will say the injectors being 1300 seems like the biggest you can get and still have drivability.
Drive ability is great with my ID2000s and E85. It's all about who you pick to tune it.
I'm noticing a little throttle leg low in the RPM's, like off idle. Other then that is pretty smooth. Car sounds way different after the new tune. Not as much cam lope as before and more of a deep vroom during idle. Up top in the RPM's it sounds the same
Thats probably the cam more than injectors.
They make 1700s now too. Then again 1300s are more than enough to make 1100rwhp on e85.
Originally Posted by bdickey058
stock fuel pump. Just a boost a pump. Holding 60lbs of pressure the whole time.
