Ecs kit fitment
Ecs kit fitment
I am having a few issues with my 2200r kit . The bracket hits the throttle body connector and the tstat housing . Any remedies ?i am using a stock z06 water pump . thanks
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Was this a used kit that was purchased? Because that is not a C6 bracket. Which is the problem. Give us a call and lets see what we can do to help you out.
Probably a C5 bracket. I had the same issues but I knew what I was getting into. Can be worked around but easier with the right bracket for sure.
This kit came off of lees c6 . I had called to verify fitment /seller a few months ago before I purchased it . You sure it's the wrong bracket ?
That's what I don't understand . Lee had a electric water pump as well as a ls7 intake . Not sure on positioning differences to the ls3 intake/tb
I noticed that in the pics. That would take care of the water pump for sure. I don't know if the throttle body sits differently on an LS7. Maybe its a C5 bracket and he never knew because it worked on his setup. I think Doug could tell you better on that.
Ecs kit fitment
Originally Posted by booztd3
Yeah Doug/ecs built the car this kit was on ,so no questioning that . I'll see if I can get some help tomorrow.
It does sit in a different location vs. an LS3. I found this out after installing an LS7 Airaid intake on my '08 LS3 car when it was N/A. Mounting grommets on the radiator cover wouldn't line up due to the throttle body location differences.
